Engine started last week, but not today
If the engine lights and then dies - try doing the same thing one or two more times - if you are still not successful, the odds are that there is either a restriction in the fuel supply line to the pump, a clogged sock in the tank, or there is a leak in that line - and the fuel pump is sucking air not gas..
To check for a restriction in the lines - the easiest way is to undo the supply line to the pump, and then push compressed air thru that line to the tank. (Ideally - it's better to push compressed air from the tank side to the pump - but getting to that line can be a real PITA.) DON'T run 90 psi compressed air - regulate the air pressure down to less than 10 psi
What do you guys use to get fuel into the carb by hand? I still have half a gallon in a spare tank from when I went to make sure the car had gas in the tank.
And the fuel is squirted into the carb where the air door opens up right? Where it looks a little bit like target crosshairs?
I'm at my wits end at this point
I feel like it's going to be something really stupid that solves the problem.
After you primed the carb - did you see fuel come out the accelerator pump nozzle when you operated the throttle linkage? I ask because it typically takes several cycles of fully depressing the gas pedal / operating the throttle linkage before the accelerator pump system is fully "primed" - and functioning normally - so if you tried starting the engine without doing so - you had no gas sitting in the intake.
And can you confirm that the carb squirts when you work the throttl (by hand)?
Either way, when I actuate the accelerator by hand there is no gas squirting out; and no, unfortunately I do not have a way to test for spark either.
OK ...- so it sounds like you did Not get the fuel into the carb float bowl. But that's OK... IMHO - the next thing to do - is to replace that rubber fuel line that's collapsed. Normally the line from the pump to the carb is under pressure from the fuel pump - but rubber line is cheap - just replace it (a lot of fuel lines made in the 1960's 1970's, 1980's, and even 1990's are not happy with the 10% Ethanol in today's gas and deteriorate fairly quickly when exposed to it).
While at the auto parts store - buy a can of Starting Fluid. After replacing the fuel line, open the throttle fully by hand, and spray starting fluid into the carb - I'd recommend about a one second spray - Max. Quickly close the throttle, and immediately crank the car over. No need to touch the throttle when cranking it over after the starting fluid. If the car runs for a few seconds - it's running on the starting fluid - and the cause of the no start is likely the fuel system. Starting fluid is not real nice to the engine, and many of us don't like to use it - but occasional use is not the worst thing in the world - just don't go crazy spraying it....
And BTW - probably the easiest way to check for spark is to pull a spark plug wire, and temporarily throw a spark plug (any spark plug - a lawn mower plug is fine) into the end of the wire. Hold the threaded surface f the spark plug against something well grounded (say the alternator housing) and have someone else crank the car over for a few revolutions (you only get a spark to a given spark plug one time for every two engine revolutions), and see if a spark jump the spark plug gap. If so - you have spark.
