Hydraulic clutch question
Old Jun 23, 2024 | 02:04 PM
Fly skids up!'s Avatar
Fly skids up!
McLeod should make clutches for class 8 trucks, some of those clutches can be brutal to drive!
Old Jun 25, 2024 | 07:43 PM
cagotzmann's Avatar
cagotzmann
Originally Posted by Fly skids up!
The kit included a McLeod street pro clutch kit, what ever that means. I start to worry when I hear the word "pro" associated with the car parts😬. I was told it's not hard to depress.
I started with this single disc clutch.
GM6-HDSS - ACT Heavy Duty Performance Street Sprung Clutch Kit | Advanced Clutch Technology
ACT GM6-HDSS. Way to heavy clutch pedal feel.
Switched to McLEOD RST TWIN DISC after 30 days. much closer to a C6 corvette manual.
But it will also depend on the hydraulic remote cylinder size for the clutch.
eg. 1-1/8th bore vs 3/4" bore. Bigger bore less pedal effort.
See if you can find someone with a clutch you are considering and experience the feel. If you like the feel of a C6 corvette, then you will need to go to twin disc setups.
