Idle Problem
Old Feb 1, 2003 | 10:03 AM
Corvette Lady's Avatar
Corvette Lady
Navigator
Default Idle Problem
I have a 1980 Corvette which I recently had the engine and carburator rebuilt. The problem I'm having is when I'm at a stop light/sign the car starts shaking. It runs very well except when I'm at an idle. Both my mechanic and the guy who rebuilt the carburator are stumped. They don't know what is causing the shaking. What's strange is the car will every now and then stop shaking and idle just fine for a few seconds and then suddenly the shaking starts again. My mechanic does not think it's the carburator, does anyone have any suggestions as to what may be causing this problem. Initally it did not pass the California smog test, so I took it to the lcoal Chevy dealer and they said it was a problem with the vacuum hoses, they reconnected them correctly, so they say, it did finally pass smog, could this shaking be a vacuum problem? Thanks for any suggestions!
Old Feb 1, 2003 | 11:48 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: Idle Problem (Corvette Lady)
It may be as simple as the idle adjust speed is turned down too low. If you can't do this, then I'd suggest you take it to a decent local garage and get a tach, timing light, and vacuum gauge attached. Start tweaking in all the parameters.
