Poor braking at idle
Old Jun 29, 2024 | 09:55 AM
hardrinseron's Avatar
hardrinseron
7th Gear
Default Poor braking at idle
Hi,
I have a bit of a strange issue. My whole brake system from end to end is brand new and under normal driving the brakes work great. However if I’m idling or driving at very low speed like parking of rolling up to junctions the pedal is very hard and braking is poor. Has anyone seen this before and can anyone offer any advice to troubleshoot it? Like i say driving normally the brakes are perfect
thanks
Old Jun 29, 2024 | 10:01 AM
Mdbirk's Avatar
Mdbirk
Manuel or power? Could need to be bled again. Maybe a vacuum leak?
Old Jun 29, 2024 | 10:58 AM
lars's Avatar
lars
How big of a cam are you running, what's it's LSA spec, and how much vacuum is your engine pulling at idle? Timing will also have a huge effect on engine vacuum - what is your timing set up to, and are you running vacuum advance off manifold vacuum to produce actual timing at idle in the high 20's or close to 30?
Also, your profile states nothing about you or your car - you might want to fill that out so we know what you're talking about...
Old Jun 29, 2024 | 02:53 PM
hardrinseron
7th Gear
power brakes. Booster is working fine at higher speeds. It almost seems like there’s not enough vacuum at lower speeds
Old Jun 29, 2024 | 02:55 PM
hardrinseron
7th Gear
Good point I will need to check the timing. I do have vacuum advance distributor. It’s connected to my Holley brawler carb. I will put a meter on it and see what it’s reading. Thanks
Old Jun 29, 2024 | 02:57 PM
Mdbirk's Avatar
Mdbirk
Lars is a god, listen to everything he has to say!
Old Jun 29, 2024 | 03:59 PM
hardrinseron
7th Gear
Sorry I’ve updated some details in my profile. I have a 1978 corvette. Not sure on any details of timing or vacuum readings at this time. I have an eddelbrok manifold and a Holley brawler carb on it though. Will test the vacuum at idle the first chance I get. Thanks
Old Jun 29, 2024 | 04:07 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Is your engine cammed? Do you still have vacuum headlight doors?. You may have a good sized leak that is overcome with engine speed. I would pull a vacuum on you vacuum booster and see if it holds it. The valve in the booster could be bad as well
Old Jun 29, 2024 | 04:36 PM
lars's Avatar
lars
And remember that us ignorant Americans don't know what a "torr" is, so post the vacuum measurment in inches of Mercury (inches Hg).
Do you know if someone has put an aftermarket cam in that engine?
Old Jun 29, 2024 | 04:43 PM
hardrinseron
7th Gear
I think it’s been canned but I’m not certain. It had a big engine rebuild by the previous owner. It does still have vacuum controller lights though.
Old Jun 29, 2024 | 05:13 PM
Bikespace's Avatar
Bikespace
Post some photos with the air cleaner removed!
Do you have a way to measure vacuum? Is your brake booster connected to a dedicated port on the intake manifold, or is something else going on?
Old Jun 29, 2024 | 05:31 PM
hardrinseron
7th Gear
it’s not connected to a dedicated port. It’s on a t connector with the vacuum ports for the lights I think. I did think about moving it but I have no more vacuum ports left
i will get something to measure the vacuum and report back. Thanks!
Old Jun 29, 2024 | 05:35 PM
Mdbirk's Avatar
Mdbirk
"torr"
He's the one with the hammer..... I think.
Old Jun 29, 2024 | 05:37 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
How do your lites open and close at idle, very simple test?
Old Jun 29, 2024 | 05:48 PM
hardrinseron
7th Gear
passenger side opens first then a second or two later the driver side opens. Is that normal?
Old Jun 29, 2024 | 06:02 PM
BPHORSEGUY's Avatar
BPHORSEGUY
No, now try the same test at higher rpm. If they work better, you are confirming poor vacuum at idle mentioned above and will then have to confirm cause!
Old Jun 29, 2024 | 06:20 PM
Bikespace's Avatar
Bikespace
Low hanging fruit:
There is a check valve where the vacuum "enters" the brake booster. You should have two or three good brake pumps even if your engine stalls. If the check valve is doing it's job, you might not notice the low vacuum at idle. You can test this with a Mity-Vac (which can also act as a vacuum gauge).
The brake booster should be connected to its own port. Please post some photos without the air cleaner attached, and folks might suggest something. Do you still have the carbon filter that keeps the brake booster from being damaged by fumes?
To Poor braking at idle
Old Jun 29, 2024 | 06:25 PM
HeadsU.P.'s Avatar
HeadsU.P.
Ding-ding-ding-ding. We have a winner!
Boosters don't like to be "T"ed with another hose.
Top Priority! You need a dedicated line from the back of the carb or a vacuum fitting on the Intake to the booster.
It should be labeled as booster hose. Larger diameter than the rest, but more importantly "thick-walled hose" so it won't collapse.
If you need lots of vacuum ports, EBay has NPT fittings that have 2,3 or 4 ports for accessories.
Old Jun 29, 2024 | 09:26 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Lars covered all the possibilities.
Engines definately make more vacuum while rev'd up, and are lowest at idle.
If they have a big cam, it can get very low at idle.
Does it sound like it has a big cam at idle? EX: How steady and smooth is it or does it lope?
Old Jun 30, 2024 | 07:46 AM
Rescue Rogers
The early cars were all Teed like that. Try disconnecting the other hoses and just having the brake line alone with everything else plugged. Keep the vacuum advance connected and try that. If there is no change increase your idle speed to 900 rpm and try again.
What is your timing set to, if it isn't at 36º with initial and mechanical (all in) with vacuum advance disconnected at 3000 rpm then set that and try again
If it's still bad I would guess you may need a vacuum assist pump. I added one years ago on a small block for this same reason. Some cams just don't produce decent vacuum at idle.
