1982 Auxiliary cooling fan temp. switch?
Old Jul 2, 2024 | 08:51 AM
Abubba1's Avatar
Abubba1
Default 1982 Auxiliary cooling fan temp. switch?
I would like to change the 1982 OEM Auxiliary cooling fan temp switch to one of a lower operating temperature. Does anyone know of the part number for one that would operate in the 200-degree range. The OEM switch that operates above the 235-degree limit is defective and needs replaced. I think a lower temp switch would be a better choice here in SE TN. Has anyone changed this switch to a lower temp? If so, any consequences? Do you know a part number or vehicle that it was used in? Any advice would be appreciated. Thanks in advance.
(After actually looking at the installed temp. switch and not going by the part spec. it seems that the switch is a double pole, not a single pole connection. Am I looking at the right switch, passenger side between cylinder 6 and 8? When I pull up a replacement switch it is a single pole application?)
Last edited by Abubba1; Jul 8, 2024 at 08:26 AM. Reason: The info initially provided is not correct.
Old Jul 2, 2024 | 11:25 AM
MelWff's Avatar
MelWff
Unaware of a lower temperature switch. Here is the stock part.
https://www.lectriclimited.com/produ...-fan-switch-6/
Old Jul 2, 2024 | 02:27 PM
Abubba1's Avatar
Abubba1
The factory switch installed currently is a single pole switch. The one listed at Lectric Limited is a double pole. A guy at our local parts store suggested a SW505 Duralast Cooling Fan Single-pole Switch that is rated at 205-degrees to contact on. But I cannot find the thread size for this particular switch. I believe I will order one just to see it will work. I can always take it back.
Old Jul 2, 2024 | 02:39 PM
MelWff's Avatar
MelWff
I think 205 with a 195 the thermostat will run continuously causing a shortened fan life. 225 would be better.
Old Jul 2, 2024 | 02:47 PM
Abubba1's Avatar
Abubba1
I have installed an all-aluminum Cold Case radiator, new fan clutch, and plan on running a 180-degree thermostat to bring down the operating temperature. That why I was looking for a temp switch in the 205+degree range. I believe it opens (cuts current) at 190-degrees.
Old Jul 2, 2024 | 02:50 PM
MelWff's Avatar
MelWff
Do you still have the original computer controlled system? It may not like a 180 thermostat. Recommend you look in the factory manual emissions section.
Old Jul 2, 2024 | 02:57 PM
Abubba1's Avatar
Abubba1
The factory spec thermostat is 195-degrees. If I lower the temperature to 180-degrees, would you expect the computer system to react unfavorably to the lower temperature? I didn't think the computer would be that sophisticated in these 1980's engines. So, would you advise against changing it to a 180degree thermostat?
Old Jul 2, 2024 | 02:59 PM
MelWff's Avatar
MelWff
I advised to do some research. It may use an early form of open loop closed loop emissions based on engine temperature
Old Jul 2, 2024 | 03:01 PM
Abubba1's Avatar
Abubba1
Will do, thanks.
Old Jul 2, 2024 | 03:46 PM
gjohnson's Avatar
gjohnson
I have an 84 and looked into the same thing and I did find a lower temp switch but I cant remember where I got it from online..They are avail. I didnt like the 235 either
Old Jul 2, 2024 | 04:16 PM
mikelino's Avatar
mikelino
I installed a Painless Wiring 185/195 switch in my 1980 L82. Works fantastic. Probably bought it from Painless or Summit.
Old Jul 2, 2024 | 04:45 PM
Abubba1's Avatar
Abubba1
I did check the logic diagrams and was surprised that most of the engine operating functions are tied to the 195+degree factory operating temperature. I guess I will reinstall the 195-degree thermostat and let it go from there. If I change it to 180-degree I'm afraid it will run me down a rabbit hole that I really don't want to be in. Thanks for steering me in the correct direction.
Old Jul 2, 2024 | 04:49 PM
Abubba1's Avatar
Abubba1
But the 1980 is a good ole' carburetor fueled engine and the 1982 is a primitive throttle body injection tied to a computer. I did the same thing to a 1980 I bought new and it ran great. After checking the operating logic on this 1982 I guess I need to leave it stock and not get into computer hell.
Old Jul 7, 2024 | 10:10 AM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
I've tried Many of the different recommended choices for fan controllers that thread in the head (between #6 & #8 cylinders) on my '84 Crossfire....my experience, time and $ invested, I'll give you for free....get a Standard TS-136!!!! Comes on around 215°f, off at around 200°f. Your fan will not run too much, if your car is moving, it shouldn't be on...if you're sitting a stop light...you want it running! Check out Rock Auto, around $45. Trust me, I spent many, many hours reading threads and tried all the AC delco choices, etc none of them had low enough "on" temps. The TS-136 is the GM equivalent of what they used on the Turbo charged Buick Grand Nationals....it works and it's the only switch I'll ever use👍
Old Jul 7, 2024 | 12:31 PM
Abubba1's Avatar
Abubba1
Thanks for the info, I checked that one out. The one installed in my car currently is a two-prong switch. But all the spec sheets for one that fits the 1982 Corvette have the single pole as the one you spec'd. Am I looking at the correct switch, passenger side between #8 and #6? Someone may have changed it to a double pole TS and one time. The PO that I bought the car from didn't change it out and he bought the car in 1987. I hope I'm looking at the correct switch.
To 1982 Auxiliary cooling fan temp. switch?
