Compression Testing - '71 350 Engine
Old Jul 7, 2024 | 06:45 PM
pg0000's Avatar
pg0000
Cruising
Default Compression Testing - '71 350 Engine
After purchasing a compression tester some time ago, I decided to test my 1971 350 engine on my C3. It was my first time performing such a test, and now I have a few questions. The results were:
1. 145
2. 140
3. 155
4. 150
5. 150
6. 140
7. 155
8. 145
After reading several articles online, I ensured that I did the same number of compression strokes (4) for each cylinder. Was this correct, or should I have continued until I reached the maximum possible compression for each cylinder?
I also read that the results should be at least 120 psi and within a 10% tolerance of each other. My results show some variation that stretches this rule. Should I be concerned about needing a new engine or a rebuild soon?
Thanks for any help!
Old Jul 7, 2024 | 07:03 PM
MelWff's Avatar
MelWff
155 the high 140 the low, you are right at the maximum variation you should find. Also a leak down test is a more accurate way of determining engine conditions.
Old Jul 7, 2024 | 07:45 PM
HeadsU.P.'s Avatar
HeadsU.P.
Your numbers are very respectable and all within the average range of each other.
Usually, the last two cylinders tested have the lowest readings. Reason being, the battery is getting tuckered out.
Always keep a charger on it during the test.
Pick two of the easiest cylinders to install your compression tester in and squirt a little oil in there.
That will give you a rough idea about the condition of the rings for all the cylinders.
Unless there is a drastic change in results, there is no need in testing the rest w/ oil.
Old Jul 7, 2024 | 07:56 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I always spin em with the throttle wide open and until they are done going up. How I was taught. And Harley Davidson still teaches to check with throttle wide open and until they stop going up. Generally within about 6 pump's.
Old Jul 7, 2024 | 08:32 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
looks good.
what are you experiencing that warrants a test?
Old Jul 8, 2024 | 12:28 PM
pg0000's Avatar
pg0000
Cruising
Thanks for all the input!
The reason for the compression test was due to some misfiring issues.
Since I’m already in the process of changing the spark plugs, which are likely the cause of the misfiring, I thought it would be a good idea to also perform a compression test.
Old Jul 9, 2024 | 10:33 AM
kossuth's Avatar
kossuth
Gotcha. You’re as far as compression goes. As somebody else stated, a leak down is a better way to look for engine issues if something has been noted in a compression test but based on your numbers no reason to even go that far TBH.
Old Jul 13, 2024 | 11:30 AM
ctmccloskey's Avatar
ctmccloskey
If you are experiencing a Mis-fire then try opening the hood after dark and look for any shorts. I have seen a noticeable decline in quality of the Spark plug Wires. Ignition coils are another great source of mis-firing as they age.
The Leak Down test is a better diagnostic test but takes more time. They perform a leak down on piston powered aircraft and record the measurements in a log book. This allows you to know when the engine needs attention.
Old Jul 13, 2024 | 01:07 PM
JavaJolt78's Avatar
JavaJolt78
Would love to know how to do a leak down check JIC???
JJ78
Old Jul 13, 2024 | 01:44 PM
drwet's Avatar
drwet
I spin the engine until the numbers stop increasing. FWIW I would be happy with your numbers.
As for leakdown tests, yes we do them in the aviation industry but only because it's a legal requirement. They are notoriously unreliable and are rapidly being replaced by a combination of borescope examination and oil analysis.
If the leakdown test appeals to you, do a search on YouTube. There are a gazillion videos on the subject. The tool is not terribly expensive.
Old Jul 13, 2024 | 09:01 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Resist the temptation to buy a Harbor Freight leak-down tester. A video-er on YouTube discovered his HF tool was giving significantly low false readings and then someone here on the forum had the same experience. I got the OTC brand and it seems like others have had good experience with it (I've yet to take readings on my engine.)
Old Jul 13, 2024 | 09:28 PM
4-vettes's Avatar
4-vettes
I work for Harley Davidson. When ever there is a engine warranty issue. They require us to submit both compression and leak down test results.
Generally, one just supports the other. The main difference is a leak down test will point you in the right direction as to where the problem is. Leaking exhaust valves will create noise in the exhaust for instance.
If a compression test shows all is good. I can't really see a good reason to run a leak down test. Unless of course the engine still has a known problem. Like excessive oil consumption.
Old Jul 14, 2024 | 05:25 AM
theandies's Avatar
theandies
I just did a cold compression test on my ZZ4 and all 8 came to 150. I was pleased and didn't have to go any further with a leak down. I think your numbers look good.
To Compression Testing - '71 350 Engine
