C3 with tremec tko issue
Old Jul 12, 2024 | 06:57 PM
klodholz's Avatar
klodholz
Default C3 with tremec tko issue
I have a completely rebuilt 71 C3 with a Tremec T5 TKOmaybe only 100 miles on it) that has been sitting for a while. It doesn't want to go into gear when hot but is fine when cold.
Not sure if this is something that was happening before but my guess is it did. I am not the original owner of the build. Any ideas to try would be appreciated! I was thinking obvious like linkage, fluid level...etc. but not sure of any other things to try.
Thank you!
Old Jul 12, 2024 | 07:10 PM
Tampa Jerry's Avatar
Tampa Jerry
Try readjusting the clutch. The PO could have installed a passenger TO bearing rather than a Corvette TO bearing. The passenger bearing will do exactly what you are experiencing. Once you get it sorted out, you are going to love the Tremec. Good luck. Jerry
Old Jul 12, 2024 | 09:02 PM
klodholz's Avatar
klodholz
Thanks! I have limited experience here. So from what I see the c3 corvette TO is a shorter 1 1/4” and the passenger vehicle TO is a longer 1 7/8”. So if it is the longer passenger one wouldn’t it be the opposite where it pulls the disc further from the flywheel?
Old Jul 13, 2024 | 07:18 AM
Tampa Jerry
No, it's the opposite. Jerry
To C3 with tremec tko issue
