1977 tire size
Old Jul 24, 2024 | 01:55 PM
sodly's Avatar
sodly
Cruising
Default 1977 tire size
Probably a dumb question but can anyone tell me the factory tire size(s) for a stock 1977 Corvette with aluminum wheels? Is it the same front vs rear? Is there a tire that is popular these days that people have had good luck with? Thanks!
Old Jul 24, 2024 | 02:54 PM
Piersonpie's Avatar
Piersonpie
GR70-15, which equates to 225/70r15 in a modern tire size. In 1978 there was an optional tire size of 255/60r15. Both should fit on your aluminum wheels without issue, although with a 255 you might need to trim a small piece of the front fender well to avoid interference.
Old Jul 24, 2024 | 02:57 PM
bmotojoe's Avatar
bmotojoe
Same size front & rear...
The largest size you can run is 255-60-15...
My current set this spring I went with 245-60-15...
Most popular brands are BF Goodrich radial TA
or Cooper Cobras
The reason I went with the 245 vs 255 just giving my wheel bearings a break...lol
Old Jul 24, 2024 | 04:01 PM
SEVNT6's Avatar
SEVNT6
I've always liked the looks of the 255 over the 225 plus there's more meat on the road. Mine fit with no problems..
Old Jul 24, 2024 | 05:24 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Been running 255's for years and years on my 77. Just about every brand. Speedo is right on and never had to trim anything.
Old Jul 24, 2024 | 09:24 PM
Stormin_Normin's Avatar
Stormin_Normin
255’s should fit, mine rub a touch on the frame at full lock.
To 1977 tire size
