Double Crimp Terminal Question
Old Jul 28, 2024 | 09:56 AM
Black72GTS's Avatar
Black72GTS
Default Double Crimp Terminal Question
I have a set of MSD cut to length plug wires and I need to crimp terminals on the end for my HEI. The double crimp terminal MSD provided with the kit does not have an obvious section to crimp the conductor part of the wire. Can I just fold the wire back on the insulator and crimp it like a single crimp terminal?
Picture of the supplied "double crimp" terminal:
I can try crushing down that "middle" section between the cup and the insulator crimp, but that tends to screw with the actual shape of the cup.
Old Jul 28, 2024 | 10:25 AM
Fly skids up!'s Avatar
Fly skids up!
Yes, just fold the striped wire back. I used this tool from Amazon. Easy to use and does makes nice crimps:
Amazon Amazon
Old Jul 28, 2024 | 11:45 AM
Mooser's Avatar
Mooser
I'm not sure those are actually the "dual crimp" terminals. (Look like regular ones to me)
The dual ones had a definite separate part ahead of the main crimp.
Those that you show should have the conductor folded back like you say
M
Old Jul 28, 2024 | 11:46 AM
Mooser's Avatar
Mooser
M
Old Jul 28, 2024 | 04:38 PM
theandies's Avatar
theandies
I've got the MSD crimper tool so I've never used those crimping blocks.
Old Jul 31, 2024 | 09:40 PM
Black72GTS's Avatar
Black72GTS
Yeah, they must not be double crimp as you say because they don't have the conductor-specific tabs. I wonder why their instructions are the way they are written... I'll try and post a photo of the instructions so that you can see that I'm not crazy...
Old Aug 1, 2024 | 12:51 PM
PBF777's Avatar
PBF777
Originally Posted by Black72GTS
I wonder why their instructions are the way they are written... ..........
Probably because the instructions were written back when that was the type of terminal being supplied, but now, with the influx of the cheaper off-shore "stuff" being put in the box, just nobody went back a rewrote the instruction sheet commensurate with the change.
Scott.
To Double Crimp Terminal Question
