R134 Conversion Adaptors - different styles?
Old Aug 1, 2024 | 11:48 AM
wadenelson's Avatar
wadenelson
Default R134 Conversion Adaptors - different styles?
After the 3rd or 4th round of repairing / converting my C3's factory air conditioning, thinking I FINALLY had it all replaced, repaired, sealed, charged, and blowing cold..
I went into the garage later that night and in the dead quiet I heard one of the R134 adaptors pissing. @#$#@!!! High pressure side.
TBH it's pretty tight and I'm not comfortable torquing it down any further. Original style compressor.
I have since heard/read there are more than one "style" of R134 Adaptors. Mine came from LAPS.
https://images.oreillyauto.com/parts...itadapters.pdf
Can anyone give me any advice on this?
Old Aug 1, 2024 | 01:18 PM
Tampa Jerry's Avatar
Tampa Jerry
Put some soapy water on the valve to determine where the leak is coming from. Could itbee from the Schrader valve? The valve is essentially a tire valve. You can screw and unscrew them with an inexpensive tool. Make sure the O-ring is well lubricated with the oil used in the system. Jerry
