Lower rad hose
Old Jul 30, 2024 | 05:32 PM
Mdbirk's Avatar
Mdbirk
Default Lower rad hose
Replacing my radiator hoses, the old lower rad hose had a spring in it, the new one doesn't. Should I swap the spring into the new one?
Old Jul 30, 2024 | 05:41 PM
mikelino's Avatar
mikelino
I would definitely put the spring in. The hose likes to kink going down from the water pump.
Old Jul 30, 2024 | 05:58 PM
Mdbirk's Avatar
Mdbirk
Mine doesn't kink, I put it on and it wasn't too bad minus the lower clamp, I was asking though because I have a high flow water pump and was worried without the spring it might suck the hose shut.
Old Jul 30, 2024 | 06:05 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Yup, that's the point of the spring. To keep the hose from sucking shut. Which they do. And this causes overheating on the highway.
Put the bloody spring in the hose!
Old Jul 30, 2024 | 06:07 PM
Mdbirk's Avatar
Mdbirk
Thanks guys! I'll be putting it in!
Old Jul 30, 2024 | 06:14 PM
Mdbirk's Avatar
Mdbirk
I can't get the old one out.....so will my local parts store have one? O'Reilly's or Napa? Local tractor supply? I live in the sticks and need the car by Saturday so ordering one online won't be here in time.
Old Jul 30, 2024 | 06:27 PM
4-vettes's Avatar
4-vettes
They can be expensive and hard to find. Cut the old hose up if you need to.
Old Jul 30, 2024 | 07:19 PM
Mdbirk's Avatar
Mdbirk
You are a genius,sir! Cut it open, used a broom stick to shove it in there and bingo bango bobs your uncle spring is in and the hose is on and I'm only bleeding slightly.
Old Jul 30, 2024 | 08:51 PM
4-vettes's Avatar
4-vettes
If your only bleeding slightly sounds like you did it just right!
Old Jul 31, 2024 | 06:09 AM
vtech's Avatar
vtech
I purchased my lower radiator hose with a Spring from Auto Zone for $12.00 for my 1978. Fit and worked like a charm, also was strongly suggested by a local radiator shop only install lower radiator hose with spring, has not overheated ever since.
To Lower rad hose
