Borgeson install complete. Not happy!
Old Aug 5, 2024 | 03:40 PM
augiedoggy's Avatar
augiedoggy
I have to make a correction.
I am currently using the stock 74 c3 control valve but I did order this 2.5gpm valve which I have not yet installed as I have not built my AN hoses yet. https://www.ebay.com/itm/264968439673
I am running the borgeson hoses with the CPP adapters and yes I also had to turn my wheels while on jackstands from end to end about 15 times while adding fluid multiple times to get the whining and jerking to stop after filling the system.
after reading this thread im now going to cnsider an an additional steering fluid reservoir or cooling heat exchanger.
Old Aug 6, 2024 | 07:29 AM
Mark60's Avatar
Mark60
Default Pump
Originally Posted by arh
The install is done and something is not right. It was not difficult to install but with dougs side pipe headers I did need to do a small amount of "clearancing". The steering feels very loose and twitchy. Also feels notchy if that is actually a word. I know it needs to be aligned but it drives very poorly. I replaced the power steering pump at the same time with a reman. Cardone 20-6886 from summit. I have seen some posts talking about too much pump pressure and borgeson sells a kit to reduce it. I also found several inline flow valves that people say work when converting to rack and pinion systems that require less flow/pressure. I am going to try one to see if it helps. Any Other suggestions?
Did you bleed air from the system after you installed the new pump?
Old Aug 6, 2024 | 09:41 AM
arh's Avatar
arh
Yes but I guess I did not get all of it. After I install the flow control fitting I will refill and try again
Old Aug 7, 2024 | 04:47 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Since the reman ps pumps are designed to fit as wide a variety of cars as possible, there is no telling exactly which flow valve they threw in there.
Old Aug 7, 2024 | 04:56 PM
arh's Avatar
arh
Installed the new valve and tried to make sure I got all the air out of the system. It is much better. My alignment is still far off and I hope to get it aligned this weekend.
Old Aug 23, 2024 | 12:48 PM
benjiboy's Avatar
benjiboy
Killer thread, thanks everyone! This will come in handy in a few months…
Old Aug 24, 2024 | 10:42 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Had one in a truck that was acting weird tried everything. It ended up being the box
