Differential question
Old Aug 9, 2024 | 07:41 PM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
Default Differential question
Hi all,
fortunately my diff was drilled and tapped for a small allen drain plug in the bottom of the case.
what type of thread seal should I use after opening it up?
thanks.
Old Aug 9, 2024 | 08:29 PM
HeadsU.P.'s Avatar
HeadsU.P.
I think I would use an Anti-seize" product. You have two dissimilar metals, iron & steel that could cause corrosion.
Much like steel sparkplugs in iron heads. A little dab on the threads.
Old Aug 9, 2024 | 10:32 PM
69L88's Avatar
69L88
Permatex 81182.
Old Aug 9, 2024 | 11:23 PM
danthony's Avatar
danthony
This seems to be a good fit. Application states differential plugs and it’s removable. I’m gonna try it.
Old Aug 10, 2024 | 12:12 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Old Aug 10, 2024 | 12:39 AM
GTR1999's Avatar
GTR1999
Depends on the plug type. I use Dry seal plugs which don't usually require sealant; however, I do use what 69L88 noted.
If you use the high temp permatex thread sealant it will work very well. I used to use it. It will also act like a thread locker and require heat to remove. After 2 guys wrecked a new plug trying to remove it 500 miles later, I stopped using it for diff plugs. I do use it on steering boxes because I want a locking sealant for that application.
Old Aug 10, 2024 | 03:51 AM
4-vettes's Avatar
4-vettes
Interesting, I personally have never had any issues with permatex thread sealer. Seems to stay soft for years.
Old Aug 10, 2024 | 12:56 PM
danthony's Avatar
danthony
Strange Gary, according to the package it’s supposed to be averse to oil and removable, they actually recommend it for differential plugs. Not that Im doubting what you encountered! This is why hearing what others have experienced is great. Thanks!
Old Aug 10, 2024 | 02:59 PM
GTR1999's Avatar
GTR1999
I spoke with the tech at Permatex after the first one locked tight. They told me exactly what was on the label. Then the two guys wrecked the plugs in a few weeks. I just put it on your steering box nut threads and want it to be locked and sealed. I will never use it on a diff pipe plug again.
Old Aug 10, 2024 | 11:20 PM
danthony's Avatar
danthony
Thanks Gary, you’re a walking encyclopedia. I’m looking forward to getting it in an not have to open it for another 50 years!
Old Aug 10, 2024 | 11:51 PM
GTR1999's Avatar
GTR1999
you will have to break in the diff and change the oil at 500 miles
To Differential question
