Trans or Rear end stuck
Old Aug 15, 2024 | 06:35 PM
Valdean's Avatar
Valdean
No, but i will verify. Thanks.
Old Aug 15, 2024 | 06:40 PM
Valdean's Avatar
Valdean
Would it only be the two outer plates that are black in your pic?
Old Aug 15, 2024 | 06:42 PM
Valdean's Avatar
Valdean
I guess thats possible.
Old Aug 15, 2024 | 06:46 PM
Valdean's Avatar
Valdean
It wont move with the clutch in. I checked my clutch linkage and it seems to be moving correctly.
Old Aug 15, 2024 | 08:26 PM
Valdean's Avatar
Valdean
I stand corrected, thanks!
Old Aug 15, 2024 | 08:39 PM
Valdean's Avatar
Valdean
Yes, the rotor turns on both wheels. Thanks
Old Aug 16, 2024 | 05:24 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Ell not moving with the clutch in is bad....time to jack it up and pull the driveshaft. If the slip yoke on the back of the tranny moves freely then pull the half shafts. If the differential doesn't spin then pull it, you can't fix it in the car. You can buy a used differential pretty cheaply and slap it in while you fix yours, then sell the temporary replacement. It will keep you on the road while there's still summer left
Old Aug 16, 2024 | 09:09 AM
n2h2o2's Avatar
n2h2o2
Sounds like a stuck E brake to me...
Old Aug 16, 2024 | 09:53 AM
Bikespace's Avatar
Bikespace
Originally Posted by Valdean
Yes you are right. Thanks
If you click "Quote" instead of just typing a reply, we can see what question you are answering, and give you better advice.
Have you crawled under to take a look and/or take some photos?
Though I didn't get the transmission stuck in two gears, I certainly had the linkage arms nearly fall off of the B&W Super T-10 transmission. Easy to fix with one hand and a gear wrench.
