Mini lite wheel for a 72
Old Aug 26, 2024 | 11:16 PM
l2vette's Avatar
l2vette
Default Mini lite wheel for a 72
Any leads on a set of four that have the factory offset would be appreciated! 👊🍺🍺
Old Aug 27, 2024 | 07:47 AM
Piersonpie's Avatar
Piersonpie
What diameter and width are you looking for?
Old Aug 27, 2024 | 03:13 PM
taint's Avatar
taint
There's a decent set on eBay right now for $895 BIN.
Old Aug 27, 2024 | 10:20 PM
Bikespace's Avatar
Bikespace
These perhaps? Don't waste time with anything but 18" wheels.
https://www.team3wheels.com/lt_iii.html
Old Aug 28, 2024 | 10:29 AM
taint's Avatar
taint
I guess he can "waste time" any way he pleases. I don't mind my 15s at all.
Old Aug 28, 2024 | 10:47 AM
Bikespace's Avatar
Bikespace
What performance tires can you find for 15" wheels? The choices aren't much better for 17". Lots of options for 18" wheels, which was the point of my comment.
Old Aug 28, 2024 | 10:56 AM
taint's Avatar
taint
I guess it depends on what your goals are for your car. Hopefully, he finds the wheel that's right for him. 🤷🏽‍♂️
Old Aug 28, 2024 | 07:01 PM
l2vette's Avatar
l2vette
Just looking for a good alternative to the factory Rallye wheel. Would like to keep the same 15 inch diameter if possible and stock offset. not interested in using spacers. Reducing the rotating mass at all four corners and keeping with the 70's trans am look! Thanks for any help!
Old Aug 28, 2024 | 07:06 PM
taint's Avatar
taint
check your inbox
Old Aug 28, 2024 | 07:50 PM
l2vette's Avatar
l2vette
Thanks Taint, I will check them out, Appreciate it!!
Old Aug 30, 2024 | 07:31 AM
cottoneg's Avatar
cottoneg
I went from 15 to 17 many years ago and have Mini lite style rims. I wanted to track my car and find that now 17 are becoming obsolete size. I am currently using Michelin PS2 sizes 255/40 ZR/ 17 for the front and 335/35 ZR/ 17 in the rear.
Not sure for how much longer. At the time, not sure 18 inch rims were available.
To the OP, if high performance rubber is not your concern, go 15 if that is what you want. I think ET Mags may have what you want.
Old Aug 30, 2024 | 11:03 AM
Bikespace's Avatar
Bikespace
For the 70s Trans Am look, perhaps the available optional YJ8 or N90 aluminum wheels are worth considering?
They are the same 15x8 size, and the same 4" backspacing as the Ralleye wheels, but weigh half as much.
Still available as new reproductions.
https://www.zip-corvette.com/68-82-c...heels-set.html
To Mini lite wheel for a 72
