Unknown engine
Old Aug 30, 2024 | 04:50 AM
Eternal Buzz's Avatar
Eternal Buzz
6th Gear
Default Unknown engine
Need some help identifying an engine
Casting # 1 GM 3970010 Mexico?
FWD pass head N5626793 MF028(0P)(0W)?
No where i look explains why the 00 at the end has PW inside the 0's.
From what i can look up it may be a 327 or 350?
Files attached as PDF's couldn't get jpegs to attach for some reason.
File Type: pdf
File Type: pdf
Old Aug 30, 2024 | 05:35 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
And you purchased this engine where? And you installed it in what car, when??
Old Aug 30, 2024 | 06:10 AM
69L88's Avatar
69L88
The 3970010 block was used in many applications beyond the Corvette. Blocks cast in Mexico have the “made in Mexico” cast above the number.
The “head casting picture” is not of a head, but the front pad of the block. The MF code is not associated with a Corvette.
Nothing special about it.
Old Aug 30, 2024 | 05:04 PM
Eternal Buzz
6th Gear
It came with the C10 truck, saw on other posts on here people were pretty good at IDing engines thought I'd ask.
Old Aug 30, 2024 | 05:21 PM
MelWff's Avatar
MelWff
Lime Book shows MF as 1967 327 Camaro
Correction, casting number wrong for this application. Need casting date.
Old Aug 30, 2024 | 05:50 PM
Eternal Buzz
6th Gear
Thank you, didn't know about Lime book!
Old Aug 30, 2024 | 06:47 PM
69L88's Avatar
69L88
The 3970010 was not installed in the Camaro until later in the 1969 production run.
Old Aug 30, 2024 | 07:04 PM
MelWff's Avatar
MelWff
We need the casting date, too many conflicting possibilities
Old Aug 30, 2024 | 07:12 PM
Eternal Buzz
6th Gear
where can i find that?
Old Aug 30, 2024 | 09:12 PM
69L88's Avatar
69L88
On the rear right “shelf”, opposite the casting number is typically where you find it.
Old Aug 30, 2024 | 11:17 PM
gbvette62's Avatar
gbvette62
It sounds like it might be a late 70's GM Targetmaster 350. I forget how to decode them and I don't have an 80's parts book nearby but I think the "M" was Mexico engine plant, "F" was June and "02" was the second of the month. They are always identifiable by the "Hecko en Mexico" cast into the rear of the block. I think the number "86" is often found cast into the back of the block too.
The Targetmaster 350 crate engine was released by Chevrolet in the late 70's. They were brand new engines based on the L-48 350, and made in Mexico that sold for $1000 or less. The Targetmaster was a complete engine less water pump, intake, carb, and distributor, with 4 bolt mains, 2 piece rear main seal, a compression ratio of about 8.5, and the L-48 cam and 76CC combustion chamber heads. It was originally released as a cheap replacement engine for commercial applications (light trucks), but quickly became popular as a replacement engine for just about anything that had a small block in it. In the late 80's it was replaced by the nearly identical Goodwrench 350 crate engine.
Old Aug 31, 2024 | 03:18 AM
Eternal Buzz
6th Gear
69L88 Ill pull it tomorrow
Old Aug 31, 2024 | 03:19 AM
Eternal Buzz
6th Gear
gbvette62 i need to do a valve cover gasket anyways ill check the number when i do that
To Unknown engine
