1979 Air Conditioning
1. How can I tell if my compressor is any good? Do I just charge the freon, and see if it kicks on?
2. I’m assuming this is the older type of freon. What needs to be done to switch to the current off the shelf freon? I started to order a full kit, but it seems like my system is complete just the compressor won’t kick on.
3. Is there something that can be used to seal leaks if there are any, or am I looking at having to completely replace a bunch of stuff?
4. If I have to replace a bunch of stuff, can I leave the stuff under the dash in place and anything new under the hood will be compatible with it?
thanks for any help or suggestions!
michael
take close pictures of system and test in particular the low and high pressure fittings prior to buyng gauges.
Next steps after above.
below a couple of ac jouneys r12 but applicable.. it is your car.
fyi the manual L82 does not have a kick up solenoid for ac. Idle is 900rpm and it will drop to about 750 when ac on.
https://www.corvetteforum.com/forums...ispreloading=1
leak here
https://www.corvetteforum.com/forums...questions.html
i did not have retrofit 134 to compare but r12 works better than my newer cars.
also note..especially your year, there was an assembler on the line that crushed the max ac recirculating vacuum line. Many reported this. Youwant recirculating ac n the hottest days. Took ver. 40 years to fix frm new lol..
Link here
https://www.corvetteforum.com/forums...cuum-line.html
