Borgeson Leaking From Bottom Seal
Old Sep 2, 2024 | 11:21 AM
ScottEwine's Avatar
ScottEwine
Default Borgeson Leaking From Bottom Seal
Happy Labor Day Weekend to all that celebrate,
I noticed a puddle under my '73 a couple days ago and traced it to the bottom seal of my Borgeson box. This is in a '73 with and LS3 that I swapped 3-4 years ago. I installed it with all new lines, a new pump and have been using GM power steering fluid. The car has been driven very little, less than 1000 miles, and I have never had to top off the PS fluid, but the leaks seams pretty substantial now that I found it. If I get the arm off is there a seal I can replace? Run some stop leak and see if that fixes it? Pull the box and take a look at it? Everything else looks good, no leaks anywhere else.
Thanks,
Scott
Frederick, MD
Old Sep 2, 2024 | 02:20 PM
ScottEwine's Avatar
ScottEwine
Update. I took it on an extended scenic drive (it is a glorious day in central Maryland) and it did not seem to leak at all. It was on a lot of somewhat windy back roads, did not do any real stop-to-stop turning.
When I park it in the garage lately I have to back it in and around the corner, and that involves about 2-3 stop-to-stop turns, and that is when it seemed to leak, seems like that is relevant.
Also, I am running a slightly smaller PS pump pulley from Dirty Dingo to clear the upper control arm so the PS pump is probably a bit over speed, could this contribute to a leak?
Thanks,
Scott
Old Sep 2, 2024 | 02:53 PM
lars's Avatar
lars
If it's leaking, replace the seal. No big deal. It's like asking, "My tire is leaking, what should I do..? Should I use tire stop leak?" No. Fix it.
The highest pressure occurs when you go lock-to-lock, so that's when it will leak. But that's also how you get the seal out - remove the arm and the snap ring, put a pan under the box, and then go all the way to the lock with the engine running: it blows the seal right out. Put in a new one and bolt it back together. Fixed.
To Borgeson Leaking From Bottom Seal
