I recently replaced the distributor in my SBC 350 aligning it in the same location as the original. The car starts well but runs a little rough and I want to double check the timing. I'm familiar with how to use a timing light but by no means expert. The block has a timing tab bolted to it with graduations from 0 - 8 retarded and 0 to 14 advanced. The harmonic damper has a gauge etched into the metal around the outside from 0 to 60. I was expecting to only see a single line or a notch on the harmonic balancer that I would I then align to the appropriate setting on the tab using the timing light (I'm wanting about 10 degrees advanced). I'm not sure now what aligns to what with both the timing tab and harmonic balancer having a range of numbers. Any advice?
Do you have a conventional timing light without adjustment or a dial back style?
If you have a conventional timing light you’ll want to line up the 0 on the harmonic balancer with the 10 on the timing tab to get 10 degrees advanced.
Although for setting up your optimal timing you’ll want 36 degrees total.
I would put a mark on the balancer at 36 degrees, and at 0 on the tab. Rev up the car with the vacuum advance unplugged and capped off until you get your maximum mechanical advance. One the marks are lined up you’ll probably find that your initial timing number will be somewhere in the mid to high teens.
If you don’t have a copy of Lars’s timing papers I would send him an email.
Thanks for the quick reply. Are you saying to time at idle to 36 deg adv which will be high teens at full mechanical advance? Won't that idle pretty rough? Sorry, who is Lars?
No, upon second read you're saying the other way around. Time to 35 at full adv which will be teens at idle?
curious the balancer is lined.
been trying to remember where I saw that before stock,
only car for sure was a ford.
anyhow, unless you suspect the "0"s don't match, pick one set of marks and time away
I should have mentioned that its not a stock motor. Its a rebuilt motor with some mild performance work done such as heads, intake, and exhaust.
When someone mentions total advance at 36*, they mean reving the snot out of it with one hand, timing light in the other.
In others words, about 3,000 RPMs.
Lock down the dizzy.
Your Intial Timing will fall where it may (10 - 16) at idle. Unimportant.
actually you are lucky because the lined balancer allows checking adv at 36, 52 deg without needing a fancy dial back light.
you can read large amount of adv with a simple basic light.
so doing the "all in" at 3000 rpm check for 36deg, no vac adv hookedup, a breeze.
Yes I run a aftermarket balancer with timing marks out to 60. It also has lines on it every 90 degrees for valve adjustments.
use only the zero mark on your tab. Use the degreed marks on the balancer. Good idea to put a white or red paint dot right on 36 degrees (If that's what your shooting for) before you start to help you see it clearly as you rev the snot out of it!
Thank you everyone for the awesome information. Incredibly helpful! I've decided to set the timing in two phases. Because the initial timing was a bit of a guess when I swapped the distributor I'm going to time it first at idle to around 10 DEG ADV. Once I've done that I will then time to 36 DEG ADV @ 3000 RPM. My logic in doing it twice is that if the current timing is a bit retarded revving to 3K straight off is likely not a good plan. Timing it at idle first means its at least close before I rev the snot out of it.
If you have the stock 1972 distributor in your car using the factory stiff advance springs, revving it to 3k rpm will not show maximum advance. You need a Mr Gasket 928G spring kit and choose the appropriate combination of springs that enable maximum advance at 3k rpm.
I have the MSD Street Fire HEI which includes optional advance components.
Then you have to check the instructions for that unit to see what has to be done to achieve maximum advance at 3k rpm. It may also tell you how much advance you get from the distributor so you only have to set initial and not rev the engine. For instance if they give you the setting for 24 degrees from the distributor internally set initial timing to 12 BTDC.
Missed this when I first read the instruction sheet.... The MSD is preconfigured to provide 22 degrees at 4,000 RPM. Seems like setting this to 12-14 at idle is a good plan and then testing the advance at 4,000 to see if it has reached 36.
They dont mention anything about springs to bring it down to 3k? With 22 degrees you want initial at 14.
They don't mention anything about springs to bring it down to 3k? With 22 degrees you want initial at 14.
Yes. They mention three things; 1/ the mechanical advance is pre-tuned to provide 22 degrees @ 4000, 2/ A vacuum advance stop kit can be fitted that allows you to limit the vacuum advance between 0 and 17, and 3/ an optional advance kit that allows adjustment of the centrifugal advance which is what I think you are referring to but it does not go into details on the adjustment ranges possible. What I don't understand yet is how the mechanical and vacuum advances interact together. For example; If I time the car to 36 @ 4000 with the vacuum disconnected does that mean when the car is in operation with the vacuum connected the total advance degrees will be 36 plus whatever the vacuum adds or does one take precedent over the other?
At cruising speeds, high vacuum, it will be a combination of the two. Ideally with 36 total mechanical you want vacuum to add another 10 to 12.
give that you now know how much advance the MSD has in it, you can set base to 14, plus the 22 in the MSD will give you the 36 yes. you will need the "advance kit" which im assuming is springs, to bring the advance in quicker.
regarding vacuum- yes you are correct with the addition of vacuum you can see total advance up into the high 40s possible 50s. that is perfectly normal for cruising "no load" situations. the minute you step on the gas and vacuum drops you lose that vacuum advance portion.
i find the easiest way for me to step timing is to use a dial back light, i paint 0 on the timing tab and balancer with white paint, set my dial back like to what i want (in your case 14 at idle) then just line up the 2 marks. done
