L-88 hoods
Old Sep 9, 2024 | 01:12 PM
Old Hotrodder's Avatar
Old Hotrodder
Default L-88 hoods
Does anyone know of a company that makes a L-88 hood that is just an inch or two taller than the factory L-88 hood rather than the 5 or 6 inches of the XL hoods out there? In my 73 I'm running a SB with Edelbrock Super Victor, 850 Holley, and 3" drop base air cleaner. ACI has a chart that shows what size blocks to place in the rails to see the clearance of their reproduction L-88 hood. When I checked, it was so close that I had to replace the wing nut with an acorn nut to get maybe an 1/8" of clearance. That is to close for comfort, but I think the XL hoods look too gaudy for my taste. I would hate to buy a new hood only to have the paint shop chop it up to add an inch or so to it.
Old Sep 9, 2024 | 04:23 PM
C3 Stroker's Avatar
C3 Stroker
This is the one you want if you can find it. Mine is the short style for 68-72. I got mine from Ecklers years ago and I like it. It's 4" high, about 1 1/2" taller than the regular L-88 hood. https://www.ecklerscorvette.com/1968...-322520-1.html
If you need the long style (73-76), here...https://stingercorvette.com/product/...all-1973-1976/ I believe ACI made them for all vendors.
Mine
Old Sep 9, 2024 | 08:37 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Machine a 1/4" off the Intake Manifold.
Old Sep 9, 2024 | 08:44 PM
Old Hotrodder
Default Thanks to C3 Stroker
Leave it to a fellow Ohioan to be the one with the answer ( I'm in Chillicothe )! Thank you so much. That 1 1/2" is exactly what I'm looking for. I want to turn that 427 SBC loose so badly, but I just can't run around hoodless like all the boys with their hopped up 4banger imports. They think it's cool but they're too young to know better. Thanks again.
Old Sep 10, 2024 | 01:22 AM
Old Hotrodder
Default still looking
I thought my search was over after the post by C3 Stroker about Stinger Corvette until I went to their webpage. They are no longer in business. Back to square one. Anyone have another suggestion?
Old Sep 10, 2024 | 05:29 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Well ACI is still very much in business. Have you tried contacting them?
Old Sep 10, 2024 | 08:37 AM
augiedoggy's Avatar
augiedoggy
I replaced my wing with a tapered countersunk bolt.pictured here it could buy you more space..
Old Sep 10, 2024 | 09:01 AM
Crimson Thunder's Avatar
Crimson Thunder
I had to do the same thing with the air cleaner nut. It's the only way to get a Performer RPM under a flat hood.
Old Sep 10, 2024 | 10:23 PM
crf311's Avatar
crf311
Corvette Dynamics
Old Sep 11, 2024 | 08:18 AM
roscobbc's Avatar
roscobbc
If using a 3" deep filter element......have you considered replacing with a 2" element and using a K & N Airstream filter top instead of the solid metal top? - that'll give you and extra inch of cleance and improved airflow with the Airstream top, more than compensate for the reduced height element.
Old Sep 11, 2024 | 08:23 AM
cottoneg's Avatar
cottoneg
Do these hoods have the cold air package like the original?
Old Sep 11, 2024 | 02:11 PM
OldCarBum's Avatar
OldCarBum
Show us some pictures of your intake, carb and air cleaner set up.
Include pictures with and without the air cleaner.
I had to go to a 1.5 inch drop base air cleaner and a perfectly flat air cleaner lid to get everything to fit.
I also had to remove my 1” carb spacer and bolt the carb directly to the intake.
Show us what you got!
Old Sep 13, 2024 | 12:28 PM
Gale Banks 80'
A lot of people have had fitment issues with the cold air package. If it's included or not I would get it separately and bond it on when it's fitted to your car. You can always buy the cold air from any vendor.
Old Sep 16, 2024 | 01:01 PM
Felix2011's Avatar
Felix2011
Mine
Not Available it says.
Old Sep 16, 2024 | 03:20 PM
C3 Stroker's Avatar
C3 Stroker
Yeah. Another great item discontinued. Maybe found on Ebay.
Old Sep 19, 2024 | 02:35 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
That's a nice looking air box. Can you spare some details on that?
Old Sep 19, 2024 | 08:20 PM
OldCarBum's Avatar
OldCarBum
Are you still manufacturing and selling your CAI’s.
Old Sep 20, 2024 | 08:17 AM
augiedoggy's Avatar
augiedoggy
I found it on ebay... Its actually made by spectre and kinda pricey but it works perfectly to seal against my greenwood turbo vented hood and works as a cowl induction type CAI I have a dual temp gauge in the car with a probe inside the air cleaner and one in the engine compartment and this setup does work as a CAI. I did have to cut like an inch off the straight edge at the rear so my hood support would clear its a drop base but they make different versions. I actually am replacing the 14" cleaner base that riveted to the base of this because im going with an ACES killshot TBI and it wont clear the drop base. these are kinda old pics and ive changed a few things but not the airtbox.
To L-88 hoods
