New Clutch
Old Sep 9, 2024 | 03:44 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default New Clutch
Looking for a new clutch assembly. Don't need top of the line exotic, just run of the mill clutch that will handle 600HP.
Any suggestions are greatly appreciated.
Old Sep 9, 2024 | 04:34 PM
gkull's Avatar
gkull
I use a ACT 11 inch 26 spline rated at 800 foot pounds. It's very easy on the left leg effort even with out H assisted
Old Sep 9, 2024 | 04:50 PM
gkull's Avatar
gkull
I'm very easy on clutches and very little slipping to take off. But I have had it behind 5 different motors in my vette and it still looks brand new. You can still see white printing on the face
Old Sep 9, 2024 | 05:11 PM
sunflower 1972's Avatar
sunflower 1972
Please read before buying: Some Facts and Numbers on Inadequate Clutch Pedal Travel Range
Old Sep 10, 2024 | 06:46 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
600 HP is not run of the mill.
perhaps looking at what racers, (above) run is a good idea.
Run of the mill is 300-350 HP . Well, in my humble opinion.
Old Sep 10, 2024 | 07:40 AM
Fly skids up!'s Avatar
Fly skids up!
As 4 Vette's said 600 HP ain't run of the mill. You're going to need to research this a bit because I'm not sure if I'm correct but I believe all of McLeod pressure plates are the same no matter the horsepower level you choose. It's only the clutch disc that's different. My McLeod clutch (street pro level) is easy to depressed. They have a Street Extreme level thats rated at to 700HP
Old Sep 10, 2024 | 11:01 AM
gkull's Avatar
gkull
You need to call these people. I have what looks like a normal patterned disc not some multi puck racing idea. People with 1000 hp turbo systems use what I have.
Clutch Kits - Manual Transmission - Products | Advanced Clutch Technology
https://www.advancedclutch.com/produ...on/clutch-kits
Old Sep 10, 2024 | 11:25 AM
gkull's Avatar
gkull
It was probably like this only 805 foot pounds rated. For tko 600 26 spline though
https://www.advancedclutch.com/produ...ung-clutch-kit
Old Sep 10, 2024 | 05:06 PM
theandies's Avatar
theandies
SPEC clutches!
SPEC
Great customer service and Made in the USA
Old Sep 10, 2024 | 09:37 PM
ddawson's Avatar
ddawson
I'm running this one behind my 502 BBC. It seems to holding fine and pedal effort feels the same as the Hays clutch.
McLeod Street Extreme Clutch Kits 75324
If you're into aggressive street driving and occasional track driving, McLeod Street Extreme clutch kits hold up to 700 lbs.-ft. of torque with street tires and moderate engine mods. These SFI-approved packages are the perfect upgrade for high-horsepower Mustangs (and other cars) that need reliable shifting on the street and the track. They feature a dual-faced ceramic friction disc, high clamp load pressure plate, pilot tool, throwout bearing, and pressure plate bolts (where applicable). You can run your pony with complete peace of mind. Street-friendly and track-proven, a McLeod Street Extreme clutch kit is your best decision. Order the model recommended for your application.
https://www.summitracing.com/parts/MCL-75324
Old Sep 11, 2024 | 02:07 PM
MotorHead's Avatar
MotorHead
+Thanks for the tips guys. I'll have to do my homework but still would like to hear what product the 600 plus HP members are running,. No more trips to the deagstrip, so just street driving.
To New Clutch
