All was fine, only thing I did that might have caused this is I hooked up my timing light positive to the positive terminal on the alternator and the negative to an engine ground.
Could that have caused my problem?
Hope you can help.
PS. It's a '78 350.
another thing I did since all was good was I changed the steering wheel. An easy simple job and not near the ignition switch.
Reason: adding vehicle information
Not the source of the problem. I connect my timing light this way all the time and have never had an issue.
Sounds like the ignition key is not changing the switch (located at the bottom of the steering column) position which …”starts, runs, turns off, and accessory functions. “
Or, a alternator that's back feeding. Sorry, I'm not there to test things. Is it a ignition switch not switching off? Highly unlikely, yet possible.
Or is it a back feeding alternator???
Could I just disconnect the alternator and eliminate that as the problem?
About stuffing towels. Story goes that Vic Edelbrock, Sr, the man that started the company, was given some nitromethane. He apparently hadn't heard of nitro before. He put it in a flathead ford engine he had in his shop and fired it up on the nitromethane. The engine roared to red line, the headers started glowing, and the dyno pegged. He turned off the ignition in panic, but the engine wouldn't turn off.....with the nitro, it was dieseling. He had to shove a shop towel in the carb to turn it off. (Story told to my tour group by Vic Edelbrock, Jr.)
He didn't have much money. His passion was sprint car racing and he couldn't compete because people with a lot of money to spend were out competing him. After his dyno experience, he began adding nitro to his sprint car gasoline and started winning money and acclaim. He started selling aluminum intake manifolds and aluminum flatheads and started the Edelbrock company. He eventually was caught out because his nitro laced gas caused eye stinging. The Edelbrock Corporation was founded on cheating! In those early days of racing, NASCAR also, cheating was an honorable way of winning.
Hi guys, I got side tracked with a few other projects and haven't done anything to solve the key problem. I've been thinking though, all was working well until I changed the steering wheel. It was immediately after I finished changing the wheel that I started it and couldn't turn it off. Guessing that I messed up something changing the wheel. Any ideas???
Does that mean you checked the switch in the interior, bottom area of steering column?
Installing a steering wheel shouldn't have touched anything to do with your ign. switch which is mounted low on the column.
Steering wheel is pretty simple and right on the very top. The only thing you could have messed with would be the horn button.
Perhaps you decided to pull your column apart when you swapped that wheel?
If not, I think your barking up the wrong tree.
Yes. You may have upset the rack gear which is connected by a rod to the ignition switch mounted at the bottom of the column. There is a pinion gear on the key tumbler which meshes with the rack gear which plunges the rod down to the Ign. Sw. to give the four different positions of the Ign. Sw. They are Accessory, Off, Run and Start. It's possible you may be off a tooth on the rack gear. Try turning the key back to the Accessory position and see if the engine shuts off. If it does then the rack gear is out of position.
This is my vote especially if you have any aftermarket electronic ignition on the car. The alternator is still making power after the key is off, and back feeds the electronic ignition.
Try shutting it off in gear, and see of the lower RPM of being in gear helps
That rack gear is under the turn signal switch. That's mighty deep for just changing a wheel. Just sayin.
Yes it is, but stranger things have happened. Aside from that, like others here have suggested, I've seen aftermarket electric fans (improperly wired) power the Ign. until the fans stop rotating,. acting like a generator. Back feeding the ignition. we are all just guessing because we can't lay eyes on the problem.
Just remember to NEVER Disconnect the Battery wire from an operating alternator while the engine is running. If I had to disconnect a wire it would be one of the two wires the ignition coil and not on a rotating alternator.
