Interior lights not working
Old Sep 29, 2024 | 08:51 AM
Darksilver57's Avatar
Darksilver57
Cruising
Default Interior lights not working
I have a recently purchased 1978, late year build date, that the interior lights don't work. The headlight switch turned counterclockwise does not turn them on. No power at either of the door switches. If i ground the bulb in each of the three lights, they light. Glove box light works, radio works, and dash lights work and dim with headlight switch. I was told that the timer was replaced and they were working prior to me purchasing. Is there a test procedure for the timer? What else might I check? Thanks
