C3 rear locked on one side
Old Oct 11, 2024 | 05:52 PM
Tigger1964's Avatar
Tigger1964
5th Gear
Default C3 rear locked on one side
Went to move my 69 a couple of weeks ago. Been sitting in a heated garage since last on road in 06. Right rear seems to be locked up. Took the brake caliper off thinking this might be the problem, but it was not . With caliper off and car jacked up, only left rear spins freely in neutral ( auto trans) Right rear will not turn. What could this be and what is my next move?
Old Oct 11, 2024 | 08:11 PM
Moved to C3 Tech for assistance.
Old Oct 11, 2024 | 08:43 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
in a posi rear, both should turn, or not.
with one turning alone, something is broke/ worn.
I am not an expert.
Old Oct 11, 2024 | 10:23 PM
kkupec02's Avatar
kkupec02
Welcome
Old Oct 12, 2024 | 03:48 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Welcome, and the cars been sitting for a long, long time.
Parking brake locked, rusted up?
Remove half shaft from back side of spindle. Does it turn? Still locked? Frozen Parking brake or Frozen bearings.
Leaving car to sit and deteriorate for that long can cause a variety of problems.
Old Oct 12, 2024 | 05:35 PM
Tigger1964's Avatar
Tigger1964
5th Gear
I will remove rotor to see if emergency brake locked up. Didn’t think car would “deteriorate” in a climate controlled garage….
Old Oct 12, 2024 | 06:37 PM
4-vettes's Avatar
4-vettes
I've been a mechanic for 50 years. I can assure you that everything deteriorates with time. Even in a climate controlled garage. Granted, it's a whole lot better being inside than out in the weather and sunlight. But Father time takes his toll no matter.
Old Oct 12, 2024 | 08:05 PM
GTR1999's Avatar
GTR1999
As mentioned above, if the 1/2 shaft is removed, that will isolate the outer axle from the diff. You can then turn the other wheel and see if the axles moves. The outer axle should spin by hand, not free wheel, but not lock up. It may be frozen parking brakes, if you rock the wheel back and forth that should break it free.
Old Oct 12, 2024 | 09:04 PM
LT1M21Vette's Avatar
LT1M21Vette
Remove half shafts first.
Old Oct 12, 2024 | 09:21 PM
Tigger1964's Avatar
Tigger1964
5th Gear
Thanks for the responses. I will give it a go and report my progress!
Old Oct 13, 2024 | 07:51 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Has the car been stored all this time with the Parking Brake set ? The Parking Brake Cables could be frozen up. By removing the Wheel and following the Cable to where it ends it attaches to a lever. Try knocking this lever aft.
Last edited by Gale Banks 80'; Oct 13, 2024 at 07:52 AM. Reason: Had my direction backwards
Old Oct 13, 2024 | 10:53 AM
Cam33's Avatar
Cam33
always check the simple things first .. you may just have a frozen caliper. A lot of owners think they are “SAVING” there cars by not driving them. Even putting your car to sleep for the winter is not good !! Nothing is moving and when spring comes along they have problems with there brakes , carburetor’s gasket leaks etc .. I personally don’t play into the whole ethanol thing either. I have never had one problem with using regular gas in over 35 years as long as i keep the gas moving and drive it often .. A car in motion stays in motion good luck
Old Oct 13, 2024 | 09:37 PM
Tigger1964's Avatar
Tigger1964
5th Gear
We’ll tonight I removed the rotor and discovered it was the emergency brake hanging up the rotor. I will put on a new rotor as the one I took off was pretty corroded. I have also decided that after owning this Lemans Blue convertible since 74 and turning 67 in a couple of weeks it is time to let this girl go. Numbers matching survivor who hasn’t seen rain in 50 years, it is time for someone else to take over. Just don’t have the passion to fix her any more and paying people to do the work is too costly. Thanks again for all of the knowledgeable responses and wish me luck!
Old Oct 13, 2024 | 09:53 PM
interpon's Avatar
interpon
May want to keep that caliper if just some rust..make sure you put back on same place you removed . Either way do a runout check.
pics of that beauty?
Old Oct 13, 2024 | 10:48 PM
Gale Banks 80'
Don't be surprised if the new buyer is older than You and plans to do his own maintenance. I think if You did a survey on this sight, You might find out as a C3 owner at 67 You might be a relative youngster.
Old Oct 14, 2024 | 01:44 PM
Tigger1964's Avatar
Tigger1964
5th Gear
Second owner since 74. Needs a little attention and perhaps paint. What is she worth?
To C3 rear locked on one side
