Master Cylinder Opinion
Old Oct 18, 2024 | 08:24 PM
starr69's Avatar
starr69
Default Master Cylinder Opinion
Hi,
Im installing new Wilwood calipers on my 69 (non power) and I can’t get a firm pedal. I have scoured through a ton of threads on here and read about alot of struggles while bleeding the brakes.
I have bench bled the MC and used a Motive pressure bleeder in the proper sequence. I’m getting good flow through all bleeders including some air, just like normal, but still a soft pedal. I have raised the back end of the car way up, unbolted the rear calipers and bled them vertically.
I was just bench bleeding the MC for the 2nd time in three days and I noticed as I was plunging it, that it had a slow weep and the rear seal, right where the push rod goes. Would this be my culprit of why I can’t seem to get a firm peddle?
Here is a pic. Thoughts?
Old Oct 18, 2024 | 08:33 PM
MelWff's Avatar
MelWff
Why did you bench bleed an old master to replace the calipers?
The seals on the master piston have been pushed into parts of the bore they normally do not pass. If there was any corrosion on those spots the seals likely have been damaged. You need to check the bore of the master and depending on what you find, either rebuild it or replace it.
Old Oct 18, 2024 | 08:47 PM
starr69's Avatar
starr69
Thanks for the reply.
The car had sit for awhile, old calipers leaked and the MC went dry.
So by me bench bleeding an existing MC, I potentially caused this end seal to leak? Would the weeping prevent a hard peddle?
Old Oct 18, 2024 | 08:52 PM
HeadsU.P.'s Avatar
HeadsU.P.
Yes. You no longer have 100% pressure build-up.
You pushed your screwdriver / master piston in too far and damaged the piston rings.
Lonestar recommends piston travel of no more than 1 & 3/8 inches.
In a bench vise, there is almost unlimited piston travel. (not good)
On the car, the brake pedal / master piston would be stopped by the floor carpet.
Old Oct 18, 2024 | 09:04 PM
starr69's Avatar
starr69
Ok, understood.
When bench bleeding a new MC, are there any limitations on the piston travel, since it’s new?
Thanks again for the help.
Old Oct 18, 2024 | 09:11 PM
HeadsU.P.'s Avatar
HeadsU.P.
Yes. 1 & 3/8" max.
Click on my avatar and look for photo album bench bleedings for tips.
I think your master cyl is toast.
It will be of no value if it weeps into the booster.
Old Oct 18, 2024 | 10:10 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Pull that master apart. Is the bore still good? If yes put a kit through it. If not, look at Tuff Stuff master cylinder or master/booster kits.
Old Oct 27, 2024 | 03:49 PM
starr69's Avatar
starr69
Ok, I installed a new master cylinder and followed all the bleeding procedures. I got a firm pedal, it won’t go any lower than 3” from the floor and the system held pressure under the motive bleeder. However, once the car was started up and everything got hot, the forward master cylinder hardline developed a slow small leak where it attaches to the MC. I have taken it apart and put it back together with the same result. Do you guys think the issue is the new master cylinder or maybe the brake line?
Old Oct 27, 2024 | 08:11 PM
HeadsU.P.'s Avatar
HeadsU.P.
That's a tough call. Can't see a thing. Only you can.
However, I am betting on the softer steel fitting of the brake line as opposed to the cast iron threads of the master.
At any time, did you or someone else insert a bolt into the master's port for the brake line?
If so, you or someone else ruined the flare inside.
Old Oct 27, 2024 | 09:02 PM
starr69's Avatar
starr69
No bolts were installed in the master port, only the plastic fittings for bleeding the MC. The brake line is “newer” however, I did take it on and off several times while trying to achieve a firm pedal with the old MC. It currently seems to be bottomed out in the new MC.
Appreciate your opinion.
Old Oct 27, 2024 | 09:24 PM
Bikespace's Avatar
Bikespace
Isn't there a cone shaped copper washer that addresses this problem?
Old Oct 27, 2024 | 09:25 PM
HeadsU.P.'s Avatar
HeadsU.P.
Is the new brake line stainless steel?
They have a bad reputation for not sealing.
Every time you took the line on & off the master, you introduced a bubble into the brake system.
Fortunately, it's the front system, easy to bleed again & again.
Are you using a Line Wrench on the fitting?
Old Oct 27, 2024 | 09:42 PM
starr69's Avatar
starr69
I’m not sure those are used for this type of connection. Not a lot of information out there on them.
Old Oct 27, 2024 | 09:44 PM
starr69's Avatar
starr69
The brake line is stainless steel, but did not leak on the old MC.
yeah, I went through a lot of fluid and time bleeding.
Yes, I’m using a line wrench on the fitting.
Old Oct 28, 2024 | 08:47 PM
HeadsU.P.'s Avatar
HeadsU.P.
The copper cones seem to work at caliper connections.
I doubt there is room for one inside the master cyl.
By chance is this new brake-line something you fabricated or is it store bought?
My self, I wouldn't use stainless if somebody paid me for the complete kit.
Too many issues. Common denominator seems to be a flare that won't form correctly due to the harness of the steel.
Brake lines of the past would rust from the inside out and outside in. Hense the reason for stainless.
But in the last decade or so, new brake lines have a coating on them that resist rust, are easily bent and forms better shapes.
Only thing I can tell you is to take a flashlight and a mechanics mirror and peek inside the masters line port. See if anything is obviously wrong with the cast iron-machined flare.
My money is betting on a flawed stainless brake line flare.
To Master Cylinder Opinion
