Vacuum advance.
Any of you guys can clarify it to me?
If you’re looking for the best way to set up your vacuum advance and ignition timing I would email Lars at v8fastcars@msn.com and ask for his timing papers.
Lars
V8FastCars@msn.com
“Ported vacuum: With that thought in mind consider if the distributor hooked to Ported Vac, as air speed increases the ported vac activates and starts to pull more and more timing in the motor as velocity increases. So if you set you total timing to 34* at 3000RPM that's when the ported starts to do it's job and advances the the timing to the total stroke of the vacuum can arm, usually 12-18* (without Limiters) so now have your total of 34* PLUS the stroke of the Canister arm of say 16* net result=50* of total timing under hard acceleration and your motor WILL "Detonate". If you had a OBD1 computer it would pull that timing back to the 34* as all the sensors feed information to it.... and no detonation.
Now to Constant: At idle/part throttle cruise you have high vacuum, the carb is nearly closed causing a restriction which creates the high vacuum level. Under this light load condition and lean AF ratios the motor needs more timing to burn the fuel (Lean Mixtures take Longer to Burn than rich mixtures) so you need more timing at idle and cruise to burn the fuel correctly and completely. When you stomp the throttle you have NO manifold Vacuum so you have NO vacuum timing and at NO time under high load will it ever advance more than the mechanical "All In" numbers. Stop pointing your finger at the carb for rich idle and top end lean conditions.. It's In Your Distributor Tuning! If your Buddy tells you to hook your Hot Rod distributor to Ported Vacuum, find a new friend because that guys advice is going to blow your crankshaft through the oil pan. Same goes for the guy who say's to disconnect it, they obviously have no idea of how it works or what it does or why we use it.
This not hear-say or an opinion its engineering, based on physics formulas, calculated by people who are a lot smarter than me and I know that so I do what they tell me. They come up with the numbers, we set them up accordingly.
If the Motor Makes 10" of vacuum or less at Idle with 30* of timing in it then it needs a properly calibrated Vacuum Can, we have Mopar and GM vacuum cans that will read 5" of vacuum.”
(From FBO ignitions)
Respectfully, FBO is FOS. The descriptions above are not at all accurate regarding how the distributor vacuum systems operate.
Made me laugh.
Adjusting ignition timing "on the fly" can give you more power, easier starting, better gas mileage, a host of benefits.
Usually this is done with a distributor that has built in vacuum advance. One vacuum line from the manifold to the distributor.
I went from a vintage mechanical-advance only Mallory distributor (350 crate motor) to a $100 generic HEI with vacuum advance. Got a noticeably smoother idle and
a minimum of 3 MPG's improvement. Night and day!
If I ever have time to follow Lars' prescription for timing adjustment I could probably get even more power / MPG's.
Just keeping things simple for the new mechanics here.
A lot of hobbyists come to the forum asking the same questions regarding timing in one form or another. The answer is definitely not coming across. Here’s an elementary explanation of what they want to know without nuance.
Corvette owners ultimately want to just drive their cars, not get lectured.
Lars has taken the time to write up a paper that describes how the system is meant to work, why it works, how it works and how best to tune it to your engine. And is willing to send that paper to pretty much anyone who asks. But to sit and retype it all everytime someone asks. Well, that's a big ask.
So, the short answer.
Basically, engine ignition timing is a process that is much like shooting ducks.
In theory, we want our spark to occur just as our fuel mixture is at it's peak compression. Right on Top Dead Center or TDC as it were.
BUT.
The fuel doesn't really burn instantaneously. It takes time for the burn or explosion to actually happen. How much time?? AHHH, thus the mystery.
So, we actually time the spark so the burn is perfectly complete precisely as the piston hits TDC. So, the faster the engine is spinning, the more we need to lead that timing out.
Back to shooting ducks.
Consider your shooting at a duck high in the sky. You don't aim at the duck. You'll miss him as your shot will fly behind him. It takes time for your shot to reach the duck just as it takes time for the explosion to happen in your cylinder. So, you aim in front of the duck to "Time" the arrival of the shot to meet the duck.
The higher the duck is in the sky, the more you aim in front. The faster the duck is flying. The more you aim in front. And then, just to keep you on your toes. There is windage!
OK, so, we have centrifugal advance to advance the timing as the engine spins faster. So the burn is completed right on TDC.
So why vacuum advance? During periods of very light load, light throttle operation,, like cruising down the highway in top gear. Or idling the engine will accept much more timing advance without causing spark knock or pre ignition. This is the windage!
The engine is pulling high vacuum during these periods. Thus, adding timing using a vacuum method makes perfect sense. Adding timing while idling, (very low engine load) or cruising down the highway, (ever notice your throttle is barely moved on the highway) anyway, adding timing at these very low engine load times will help the engine run cooler, and more efficiently. And as soon as you step on the throttle, the butterfly's in your carb open up, the vacuum drops right off, vacuum advance let's go and your back strictly on the mechanical advance.
And that is the short answer.
Lars
V8FastCars@msn.com
(C’mon really, how can anyone take you guys serious)
BUT.
(Another Lecture)
I get the one stop shop Lars provides for this forum, Great!
Model A Fords had a Timing advance/retard lever right at the steering wheel. This stuff is not rocket science.
The engines that are in the Corvettes are Chevrolet engines installed in passenger cars and trucks.
The information regarding ignition timing is available on any muscle car, hot rod enthusiasts website. And it is the same for all V8 engines, Chrysler, Ford, GM.
Heres a great link from Hot Rod regarding ignition timing.
https://www.motortrend.com/how-to/ig...-hp-heres-get/
