77 L82 head upgrade options
Old Oct 26, 2024 | 11:52 AM
sangreti's Avatar
sangreti
Default 77 L82 head upgrade options
I am working on a retromod of a 77 I plan to give to my dad, the stock heads are well, FILTHY because they leaked like crazy and smog sucks. So, I was looking into a cheap upgrade or replacement but I don't know the stock spec. would anybody be able to tell me the stock spec and potentially recommend a reasonable upgrade? I am not looking to make some monster, stock is probably fine but the amount of money and time id put into referb on the heads probably equals or approaches the cost of a new head.
Old Oct 26, 2024 | 12:35 PM
randallsteel's Avatar
randallsteel
Stock is 76cc chamber(that’s why your compression ratio is so low, 8.5:1)
If you’re replacing the heads, and can swing it, I would recommend replacing the iron 76cc head with an aluminum head, 64cc chamber. Lighter, better flowing, and will bump your CR up improving drivability and power.
im a fan of the edelbrock estreet 5089 heads in terms of price vs performance, but honestly Trick flow, Brodix, AFR all make good heads.
Old Oct 26, 2024 | 12:48 PM
sangreti's Avatar
sangreti
thank you! i was looking at some afr 1001 heads they were only about 1k assembled ill take a look at the 5089s
calwldlife's Avatar
calwldlife
St. Jude Donor '22
couple of differences on heads.
chamber size, like 76cc 60cc etc. this affects comp ratio.
smaller means more compression and more potential power.
valve diameter, 2.02 1.92 etc. affects air entering cylinder. bigger more potential.
you can google the head number, found under valve cover.
like "gm 3932441 head"
comes back 70 76cc 1.92 int valve gen 1 sbc
last spec usually found on new heads is intake runner size,
like 170 cc 180cc 190cc 200cc etc, this is potential velocity of intake air path.
yes, machine work, finding an old head/s, and increasing performance gets frustrating when the sellers of old heads think they have gold. machine shops are expensive.
new alumn heads are a viable choice
Old Oct 26, 2024 | 05:31 PM
Stormin_Normin's Avatar
Stormin_Normin
I would get a set of whatever 180 cc heads with 64cc chamber aluminum heads fit your budget. You can get a set under $1k, it’s not really worth messing with the stock heads. You will probably need longer push rods and roller rockers also. The 64cc heads will give you about a point more compression.
Old Oct 27, 2024 | 08:53 AM
LenWoodruff's Avatar
LenWoodruff
We put the Edelbrck Performer 2.02 heads with the 176cc runner size when they rebuilt my L82.
Old Oct 27, 2024 | 09:01 AM
ctmccloskey's Avatar
ctmccloskey
The AFR heads for $1000.00 is a nice as cast finished cylinder head and is priced to be affordable. The were tested on Engine Masters and they did very well.
Compression Makes power so simply add some compression and make some power. I did it to my 427 and wow, what a difference. Just realize that once you change the cylinder head the engine will have to find the right timing to make it run perfectly.
Old Oct 27, 2024 | 09:30 AM
7t9l82's Avatar
7t9l82
64 cc. Heads on an L-82 gets you to about 10-1 compression then get a cam specific to your application.
To 77 L82 head upgrade options
