69 Pulley Alignment issues
Old Nov 4, 2024 | 11:34 AM
malicatasr's Avatar
malicatasr
Default 69 Pulley Alignment issues
I purchased a numbers matching project 69 convertible 300 hp base engine. The engine was out of the car and rebuilt when I picked everything up. Upon inspection I couldn't install the engine with a 55 year old balancer. It was cracked and dry. To me it didn't make sense to install a old balancer. Well the lower pulley's don't line up with the water pump pulley. The water pump pulley is in front of the crankshaft pulley by maybe 1/4". When I pressed in the balancer you usually keep going until it stops. The balancer typically presses against the crank gear. So I'm not sure which way to go because my problem is the exact opposite of what normally people encounter when they don't press it in enough. Any help would be appreciated. When I had the old and new balancers together they looked identical even the snout. Any help would be appreciated.
Old Nov 4, 2024 | 12:32 PM
carriljc's Avatar
carriljc
malicatasr
Did you get an exact replacement balancer? Did you compare it to the old one?
If so then we can save some time if you post all the pulley numbers.
Let me get a chart I made for my 68..... should pretty much help you get the correct pulleys.
Gimme a sec... meanwhile look at your 1969 AIM for pulley numbers..... so you can compare them with the list I'm going to go get....
Old Nov 4, 2024 | 12:35 PM
carriljc's Avatar
carriljc
malicatasr
Here you go.... a place to start: https://www.corvetteforum.com/forums...post1595410814
Old Nov 4, 2024 | 01:25 PM
malicatasr's Avatar
malicatasr
Thank you for posting the previous post.
My crank pulley is 3850838
PS pulley is 3751232BB
I'm not 100% on the water pump pulley, will check after work today.
I do not have A/C and the air pump is long gone.
Looks like the correct pulleys, my car is a 69 early (September 68)
Should I have a concern reinstalling a 55 year old balancer. There are no hammer marks on it. It just looks old. (Like me). When I get home I'm going to pull the new balance and visually compare to the new. Which I did but not with calipers.
Old Nov 4, 2024 | 01:58 PM
MelWff's Avatar
MelWff
What manufacturer and part number is the new balancer?
Old Nov 4, 2024 | 02:08 PM
malicatasr's Avatar
malicatasr
The balancer was purchased from Jegs, the p/n is 51653.
Old Nov 4, 2024 | 03:30 PM
carriljc's Avatar
carriljc
malicatasr
Compare the new balancer with the old balancer. Ensure it is built the same. Share some pictures.
Old Nov 4, 2024 | 03:37 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
if its close you can buy shims to bring the water pump pulleys out to line them up.
Old Nov 4, 2024 | 04:04 PM
J.Abbott's Avatar
J.Abbott
The assembly manual will tell you exactly what pulleys and balancer for what hp with what options your car had. It lays it all out.
Old Nov 4, 2024 | 08:02 PM
MelWff's Avatar
MelWff
That 8" balancer is typically found on the 350/350 not the 350/300. Did you compare the diameter?
Old Nov 4, 2024 | 08:24 PM
carriljc's Avatar
carriljc
malicatasr
Find the correct pulleys. Do you have the AIM? If you find the correct pulleys you don't need to shim anything.
Old Nov 4, 2024 | 09:20 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Do you know if the water pump is the short-design* for your '69? What is the pilot shaft diameter (the nub the fan clutch mounts to)? How much space is there between the rear plate of the water pump and the timing cover? If you can fit your hand in between, then it's not a Corvette pump and will push your WP pulley outward and out of alignment.
*All Corvettes used a "short" leg pump but there were two of them – a 5/8" pilot shaft up to 1970 and a 3/4" pilot shaft from '70 up.
Old Nov 4, 2024 | 09:28 PM
carriljc's Avatar
carriljc
malicatasr
See this post. Hayes69 posted an image of an AIM page and I think it is a 1969.
Should have some relevant pulley numbers needed. You can then use that gm wiki webpage to cross reference with alternate pulleys.
https://www.corvetteforum.com/forums...post1595069037
Old Nov 5, 2024 | 12:08 AM
Tuna Joe's Avatar
Tuna Joe
Can’t you have the old harmonic balancer rebuilt?
www.damperdoctor.com
Old Nov 5, 2024 | 08:55 AM
malicatasr's Avatar
malicatasr
So I checked last night compared the old and new balancers and they are almost identical. The new one is .001 shorter in the snout. That's nothing in my eyes. They are both 8 inch, the machined face to a flat surface are the same. My .
My pulley's are:
Crank pulley: 3850838
PS pulley: 3751232BB
Water pump pulley is 3890419 - according to the AIM my base 300 HP should be 3876846. The 419 is for the 327.??
I also have a short water pump.
Balancer is 7704H
I haven't even gotten to the alternator yet. I want to clean up the exhaust manifolds before I put them on. So who know what joy that's going to bring.
So I pulled the new one and checked and reinstalled and once again when it bottomed out it was still offset. So I measured the distance to the front of the timing tab as a reference. I then pulled the new balancer out a little bit and aligned everything and re took the same measurement. It's 3/16 of .1875 difference. I saw crank pully shims online and was going to try them. I really don't want the balancer not seated properly.
Old Nov 5, 2024 | 09:03 AM
malicatasr's Avatar
malicatasr
I never knew balancers could be rebuilt. Thank you.
Old Nov 5, 2024 | 11:37 AM
carriljc's Avatar
carriljc
malicatasr
I previously forwarded this table-- it is within a link above....anyway, you have this info available to make your decision for pulleys that will align. Take a look at this table... and you might want to read the whole post anyway. The link and table lets you know what will align and mate (as far as the forwardmost pulley).
Since you now know which pulleys to get I suggest checking ebay. Pulleys last forever and you'll find the best prices there.
https://www.corvetteforum.com/forums...post1595076578
My pulley's are:
Balancer is 7704H
To 69 Pulley Alignment issues
Old Nov 5, 2024 | 11:54 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Hello. We would recommend bringing this concern to a Chevrolet dealership who can provide expertise guidance and answer your questions in greater detail. Should you need help connecting with one in your area, please email us at socialmedia@gm.com.
Old Nov 5, 2024 | 12:41 PM
carriljc's Avatar
carriljc
sure
Old Nov 5, 2024 | 01:57 PM
MelWff's Avatar
MelWff
Originally Posted by carriljc
malicatasr
​​​​​​​That table appears to be for a 1968, the OP has a 1969.
