Electrical problem
Old Nov 5, 2024 | 06:35 PM
bg725's Avatar
bg725
Default Electrical problem
1968 coupe showing a high resistance short to ground with the car off. The battery drains overnight to the point that car won't start. Pulling the instrument fuse results in no short. With the fuse pulled all gages work accept the water temperature. Gage. With the fuse in the the water temp gage works as it should. As I understand it, the 12 volts to the gage is switched through the ignition switch. Could the ignition switch be the culprit.
Old Nov 5, 2024 | 06:48 PM
randallsteel's Avatar
randallsteel
High resistance short?
A short implies a low resistance.
If you are having a battery drain and there is no evidence of a short, then I would investigate all non-linear circuit elements in the car, anything that is a semi conductor.
the voltage regulator on the alternator is a common culprit.
try disconnecting your alt and see if the drain goes away.
Old Nov 5, 2024 | 06:53 PM
Richard454's Avatar
Richard454
On a 68-
Check the wiper bypass **** under the steering column and see if it is on.
Old Nov 6, 2024 | 06:51 AM
pigfarmer's Avatar
pigfarmer
If you can measure the fault reliably with a meter then pull fuses one at a time and see if the fault goes away, at least hat would help you narrow it down.
A battery disconnect on these old cars is usually a good idea even without a parasitic drain.
Old Nov 6, 2024 | 07:54 AM
Bikespace's Avatar
Bikespace
It's either fused (pull all the fuses), or not.
If not fused, it's either a pinched wire between the battery and fuse panel, or more likely your alternator.
I'd start with the alternator myself.
Old Nov 6, 2024 | 09:42 AM
ctmccloskey's Avatar
ctmccloskey
Harbor Freight carries these devices that plug into a fuse slot and then it shows how much current is flowing through the circuit. They were less than $25 when i bought mine.
On the 1968 C3 the most common grounding issues was mentioned by Richard454 and that is to check the position of the windshield wiper bypass switch which allows you to stop the wipers to change them. If that switch is left on it will drain your battery down. Be sure to check the entire wiper system for any problems.
Other places to look are at you alternator and be sure that it is not the culprit, bad diodes in the diode bridge can suck power continuously. This too is way to common a failure mode even in this day and age.
I had an interior light switch that was shorting and pulling a tiny current which was a slow drain on the battery.
Old Nov 6, 2024 | 10:30 AM
carriljc's Avatar
carriljc
bg725
You may also have interrupted the 1968 wiper system operation and relay behind the tach is staying energized (and there is nothing wrong with the system other than the goofy design).
A quick check is to listen for the relay as you disconnect and connect the negative battery terminal. It is rather obvious when it CLICKS.
Let me find a post on that.....in case it is just and interrupted wiper start......
Originally Posted by Richard454
On a 68-
Old Nov 6, 2024 | 10:37 AM
carriljc's Avatar
carriljc
bg725
FYI - in case it is a case of wiper start interruption:
https://www.corvetteforum.com/forums...post1607052246
Old Nov 6, 2024 | 11:04 AM
OldCarBum's Avatar
OldCarBum
Have you done any recent maintenance to the car?
Check any new electical components you installed to make sure the new parts aren’t causing your drain.
Check any connections to electrical component to make sure everything is taught.
Another thing to consider is, the wiring insulation on our cars is 50+ years old, it becomes brittle with age and sometimes the slightest movement can crack the insulation and cause intermittent shorts.
After checking the items listed by the other’s, start following all the wires running adjacent to the frame, engine and anything metal to see if any wire insulation has rubbed and exposed the wire strands.
The best advice, listen to the forum members above, they know the electrial systems on our cars and Richard454 is considered the electrical guru.
To Electrical problem
