Old tire date code question
Old Nov 8, 2024 | 09:37 AM
Paul71LT1's Avatar
Paul71LT1
Default Old tire date code question
Does anyone know how to properly interpret this date code information? I found an old but never used goodyear speedway tire at my local swap meet last Saturday with the following code molded in: " ATNBL JD1". My only takeaway from all this is that is was likely made in 1971 with the 1 being the last character. Can anyone confirm this or shed any light on the meaning of the other letters?
Never used Goodyear Speedway tire
Portioin of the original tag stapled to the tread surface
Portion of the original tag stapled to the tread surface
Old Nov 8, 2024 | 10:22 AM
PJO's Avatar
PJO
Veteran: Marine Corps
AT= April 15th week 1970 NB= Akron Plant LJ= Tire Size D1=Type
Old Nov 8, 2024 | 10:52 AM
sunflower 1972's Avatar
sunflower 1972
Old Nov 8, 2024 | 01:16 PM
MelWff's Avatar
MelWff
Originally Posted by sunflower 1972
That's only for tires made after 2000
Old Nov 8, 2024 | 01:17 PM
MelWff's Avatar
MelWff
The DOT code should be on the back of the tire for a pre 2000 tire. Is the code you posted from the back?
Old Nov 8, 2024 | 01:50 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Best looking tires ever......
JIM
Old Nov 8, 2024 | 08:32 PM
Paul71LT1's Avatar
Paul71LT1
The code I posted is on both sides of the tire. In the first photo you can see it at top center near the "G" in goodyear.
Thank you PJO for the detailed breakdown. I do know how to read currently used date codes. It was the ancient history I was looking for and that's what you provided.
Old Nov 8, 2024 | 10:49 PM
hunt4cleanair's Avatar
hunt4cleanair
Post a photo...I suspect that's not the date code. You looking for the DOT either above or in front of the code data.
Here is link to article with photos with discussion of date codes
http://www.hunt4cleanair.net/Article...tiresafety.pdf
Old Nov 9, 2024 | 11:07 AM
Paul71LT1's Avatar
Paul71LT1
Here's two more photos showing the back of the tire. There is nothing under the "DOT" marking on the back. The molded in information that I originally posted is shown to the left and is identical to that which is shown on the front.
"DOT" marking with nothing under it from the back of the tire
There are also two identical red ink stamps on the back of the tire indicating where is was made and where it was sold. They read:
"GOODYEAR T&R CO. GADSDEN ALA - 5000", and "GOODYEAR SERV STORE, 901 MARKET ST N, CANTON OHIO"
Red ink stamps
Red ink stamps
Old Nov 9, 2024 | 11:37 AM
MelWff's Avatar
MelWff
Red ink stamps
Red ink stamps
The date Code after the DOT didn't start till sometime in 1971 which explains the format of the date code on your tire according to an article on the Coker Tire site.
Old Nov 9, 2024 | 12:18 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
My understanding is that until 1971 when the government mandated universal date codes from all manufacturers, each company had its own system. Your tire is prior to the standardization, so relies on GY's system. PJO above decoded it.
This PDF article, Goodyear Polyglas Tire Date Coding by Marcus Anghel and Rick Sauve, may provide some info for background on decoding.
File Type: pdf
Old Nov 9, 2024 | 06:46 PM
Paul71LT1's Avatar
Paul71LT1
Thank you for the pdf file which I have saved to my PC for future reference.
Old Nov 9, 2024 | 09:31 PM
PJO's Avatar
PJO
Old Nov 10, 2024 | 03:13 AM
hunt4cleanair
Originally Posted by 67:72
My understanding is that until 1971 when the government mandated universal date codes from all manufacturers, each company had its own system. Your tire is prior to the standardization, so relies on GY's system. PJO above decoded it. This PDF article, Goodyear Polyglas Tire Date Coding by Marcus Anghel and Rick Sauve, may provide some info for background on decoding.
This is an excellent summary of Good Year tire date code formulation in the 1970s...and as it evolved in the same decade. Nice work!
Old Nov 10, 2024 | 07:53 AM
ctmccloskey's Avatar
ctmccloskey
It is so hard to imagine what my C3 with it's 427 would have done to that size tire, that being the size my C3 BB came with from the factory. It might be worth a laugh or two to try a set of 4 of the older F-70-15 sized tires and see just how different our modern radials are.
To Old tire date code question
