72 louver bracket question
Old Nov 13, 2024 | 08:14 PM
Benbuilder's Avatar
Benbuilder
Default 72 louver bracket question
I recently determined that someone work had been done to my passenger side fender. As a result, there is no way to correctly mount the top of the louver. Page A13 or M235 of the AIM shows a bracket that is called REINFORCEMENT, number 3963168. I am missing this piece. I am sure i can fab something up or buy it from one of the suppliers. How does it get installed? Anyone done it?
Old Nov 14, 2024 | 03:12 PM
sunflower 1972's Avatar
sunflower 1972
I'm thinking it's probably bonded. What does the left side look like?
Old Nov 14, 2024 | 03:14 PM
Benbuilder's Avatar
Benbuilder
looks like factory bonded. so i guess i need a good bonding agent? I dont think fiberglass is a good idea.
Old Nov 14, 2024 | 09:22 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
It's just an angled fiberglass bonding strip but it's waaaaay backordered from CC. Being fiberglass is no issue as it only holds the U-clips for the side vents' sheet metal attaching screws. When bonding this type of part, 3M 08115 is perfect – it's a quality 2-part panel bonding epoxy.
Corvette Central 3963168
Old Nov 16, 2024 | 06:41 AM
Benbuilder's Avatar
Benbuilder
I am going to make this part myself out of fiberglass sheets by laying them into a piece of angle iron then bond it to the car. thanks for the tip on how to bond it. I will use tinfoil or something to keep the resin from attaching to the angle iron.
Old Nov 19, 2024 | 04:59 PM
Benbuilder's Avatar
Benbuilder
for anyone who is going to make this bracket, i am going to give you the info i derived from the driver side bracket in which i duplicated.
The length is about 12"
the width of each side is about 1" I am not done yet with mine but i know 1" is enough for the installation of the clips to hold the grill
the angle is not 90 degrees as i had previously stated. It is about 118 degrees.
I made a mold out of two pieces of pine with a 118 degree angle. I layered the mold with blue painters tape
I then cut pieces of fiberglass matting about 3" wide and laid in about 3 pieces with the resin.
once it cured, i trimmed it up. now i am waiting for the bonding agent to come in the mail.
To 72 louver bracket question
