...I've got halfshafts hanging loose and a driveshaft that's out of the car completely.
Somebody tell me that doing the U-joints now would be a smart move and that I may not need a press to do them. Or that any number of local shops can press in new U-joints very inexpensively.
I've got the grease-able ones now and want to step up to solids. Anybody have a Spicer or Brute Force P/N for the halfshafts (4) and driveshaft (2) U-joints for a '76 with auto?
Re: While the differential is out for re-gearing... (The Dude)
I replaced all six of my U-joints in my '73 and did not use a press. It wasn't amajor job, just a PITA. I just used the replacement U-joints from Ecklers.
The 1/2 shafts can be a problem. If you press them you must support the flange or you'll bend it for sure. If you have a oxy torch then you can cut out the cross section and hammer them out. Do a search there's a lot of info on U-joints in the files. Check a truck part supplier for Spicers.
Gary
Don't go with the Brute Force U-joints.. Check the Drag Race section for feedback on the Brute Force ones... They frequently break... I used the solid Spicers. The part number (new part number since a couple of months) is 5-799X
:cheers:
Olivier
P.S. I use solid spicers and pull high 1.50's to mid 1.60' 60' times and so far no problems with them...
