Fuel not getting into carb
Old Nov 17, 2024 | 04:23 PM
Jagamaphone's Avatar
Jagamaphone
8th Gear
Default Fuel not getting into carb (FIXED)
Just went through and replaced all the carb gaskets and put everything back together and now fuel isnt getting into the carb. We took the fuel line off and primed it and that checked out then we took the filter off and it wasnt clogged or anything. We noticed the accel pump makes an air noise both old and new one we got. Hitting the throttle doesnt squirt any fuel. Ill provide photos and videos if needed but we're not sure where the fuel is even going.
Old Nov 17, 2024 | 05:02 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
What make and model of carb are we talking about?
Pics would be good so we are all referencing the same thing.
Old Nov 17, 2024 | 05:11 PM
Piersonpie's Avatar
Piersonpie
OP is working with a Quadrajet, going off of their other thread.
I would check to make sure your fuel filter is installed the correct way, with the fuel flowing into the hole on one side and exiting through the pleats in the filter. Installing the filter backwards with the blind end of the filter facing out can prevent fuel from flowing to the carb.
Old Nov 17, 2024 | 05:12 PM
lars's Avatar
lars
Deleted
Jagamaphone
8th Gear
We actually just got it running lol so we're good. Its running a lot stronger my only concern was one time while punching it it seemed to just stop at 4k. Other than that, seems a lot better but yes it is a quadrajet off a 79 corvette the # of it is somewhere in my other thread
Old Nov 17, 2024 | 05:13 PM
Jagamaphone
8th Gear
Originally Posted by lars
If you have fuel pressure and fuel is not getting into the carb, you have assembled your float/needle/seat incorrectly. There is more to rebuilding a carb than changing the gaskets...
i believe our set needle was off center and we slapped our new accel pump in and it seems to run good now
Old Nov 17, 2024 | 06:49 PM
Piersonpie's Avatar
Piersonpie
I’m not quite sure how the needle can be off center if it’s inserted into the seat.
Is the needle clip installed in the correct place? Along the inner side of the float lever.
Glad you were able to get it running though.
Old Nov 17, 2024 | 06:51 PM
Jagamaphone
8th Gear
Is the needle clip installed in the correct place? Along the backside of the float lever.
the clip that hangs on the needle was on the hole not centred if that makes sense lol. Apparently its not supposed to be regardless it runs now
Old Nov 17, 2024 | 06:56 PM
Piersonpie's Avatar
Piersonpie
Dang you responded before I was able to edit my comment, I don’t mean the back side of the lever. I mean the inside, like this.
Old Nov 17, 2024 | 07:09 PM
Jagamaphone
8th Gear
yeah mine looks like that now. It was hanging off on the hole which maybe caused it to not get fuel
To Fuel not getting into carb
