Clutch Peddle Shaking
Old Nov 26, 2024 | 07:33 AM
jonsheritage04's Avatar
jonsheritage04
Cruising
Default Clutch Peddle Shaking
Hi Guys,
I have a 75 four speed and yesterday the clutch peddle started shaking while in neutral. There is also a ‘spinning’ noice coming from the trans until I depress the clutch. Not sure if this may be something simple or am I losing the trans. I can work through all the gears including reverse without any issues or sense of slippage
Thanks for any thoughts
Old Nov 26, 2024 | 08:15 AM
interpon's Avatar
interpon
went thru this..
https://www.corvetteforum.com/forums...n-neutral.html
advice ranged from pilot bearing / bushing/ clutch adjustment to make sure you have free play..
in my case it was not
Pilot Bushings and Bearings
To check for a noisy pilot bushing, begin listening for noise after starting the engine. Listen for noise with the engine running, the transmission in gear, and the clutch pedal to the floor. The clutch is released, but the transmission is in gear, which causes the engine crankshaft to spin around the held transmission input shaft. Noise under these conditions indicates a worn pilot bushing or bearing, or a worn release bearing.
BUT I FOUND THIS!!! its not really a noise but vibration.
A bearing noise that occurs if you release the pedal to engage the clutch while in neutral, but goes away when the pedal is depressed, is caused by a defect on the transmission’s input shaft bearing.
this thread fixed it
https://www.corvetteforum.com/forums...etc-diy-3.html
Old Nov 26, 2024 | 06:10 PM
jonsheritage04
Cruising
Thank you, I will try the rod adjustment tomorrow
Old Nov 26, 2024 | 07:36 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
Pedal
Old Nov 28, 2024 | 09:44 PM
jonsheritage04
Cruising
Thanks guys, I found that nut B had worked out and was not tight against the swivel. All is right again
Old Jul 4, 2025 | 09:27 PM
Redd Fox's Avatar
Redd Fox
Thank you all for your input and advice. I am deciding which way to go with this and your advice helped.
Thanks again
To Clutch Peddle Shaking
