Shifter wont go to reverse.
Old Nov 26, 2024 | 02:11 PM
Racerjoe's Avatar
Racerjoe
Default Shifter wont go to reverse.
Anyone know how to remove the shifter on a 73 with a 4 speed. It wont go into reverse and I can see where it is being prevented from moving but need to take it out to get to it.
Old Nov 26, 2024 | 02:18 PM
JETS C3-C4's Avatar
JETS C3-C4
You should re-post on the tech board you would get more results.
Here is a link to where to post your question:
https://www.corvetteforum.com/forums...performance-3/
Old Nov 29, 2024 | 11:27 AM
Racerjoe's Avatar
Racerjoe
Thats great, Thanks. Still trying to figure out how to do the post. So can I ask you how did you see the post I did, I'm not sure other than I saw a post button and used it to post. Anyway, thanks again,
Cheers
Old Nov 29, 2024 | 04:16 PM
JETS C3-C4's Avatar
JETS C3-C4
Hi Joe,
I saw your post when I was looking at the " Auto Extras & Memorabilia" board postings and read it there.
I see you have posted in the Tech board now so you got it figured out.
Good luck and hope you get an answer soon.
Old Dec 1, 2024 | 12:51 PM
vettebuyer6369's Avatar
vettebuyer6369
Moving to C3 Tech
Old Dec 1, 2024 | 03:00 PM
sunflower 1972's Avatar
sunflower 1972
https://www.corvetteforum.com/forums...r-removal.html
Old Dec 1, 2024 | 08:09 PM
Bikespace's Avatar
Bikespace
Can you get under the car safely? It is possible that one of your linkage arms has come loose. Can you get into reverse if you move the arm manually with a wrench?
Old Dec 1, 2024 | 08:30 PM
J.Abbott's Avatar
J.Abbott
The reverse lockout rod ( T Handle) can break and when that happens the rod is stuck in place, so eventhough you are pulling up on the T handle it is not moving to get the shifter into the reverse slider.
Old Dec 3, 2024 | 05:17 PM
Racerjoe's Avatar
Racerjoe
Hey, I got lucky, not sure how I did it but it worked. Also, I found the problem. It was a broken spacer in the shifter assembly. Ordered a new one so hopefully it will fix the problem. Thanks for all the help
To Shifter wont go to reverse.
