Issues identifying cable+can
Old Nov 28, 2024 | 04:19 AM
777max's Avatar
777max
Default Issues identifying cable+can
Hey Guys. Im currently trying to figure out which parts i need to Order. Ive stumbled upon a disconnected cable. Can anyone Help me identify what that is? My first thought was Kickdown cable but ive never Seen the Vacuum can IT connects to. Would really Help If someone could explain how it works. Last Time i drove the vette the Kickdown worked which is Strange because the can, afaik, was never connected to the cable.
Old Nov 28, 2024 | 04:55 AM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
That is the cruise control
Old Nov 29, 2024 | 12:34 AM
bmotojoe's Avatar
bmotojoe
Yes, that is the Cruise Control Servo.
Both the Servo & the Cable are 1977 1 year only parts.
The Cruise Transducer (if is still there) is mounted down below the master cylinder area.
Old Nov 29, 2024 | 02:19 AM
777max's Avatar
777max
Thanks a lot. So there should be No issues ignoring it, right?
And the Kickdown is Controlled by a Modulator?
Old Nov 29, 2024 | 04:43 AM
ralphspears
Banned Scam/Spammer
Yes, ignore it it has nothing to do with the kickdown
Old Nov 29, 2024 | 06:59 AM
bmotojoe's Avatar
bmotojoe
On your intake manifold behind the carburetor there is a 3 way vacuum fitting. The center or top port should have s short piece of vacuum line conneted to a steel pipe, that line connects to the modulator valve of the transmission.
One of the ports of the 3 way fitting (generally the side facing passenger side) feeds the Cruise Transducer. That should be capped off if the Cruise is inoperable.
To Issues identifying cable+can
