Bypassing generator for alternator
Old Nov 30, 2024 | 06:53 PM
Jd21476's Avatar
Jd21476
Default Bypassing generator for alternator
I am running an alternator on my ‘68. I just replaced the factory engine harness and I believe the ‘68s used to have generators. I looked online and this showed how to bypass the generator for the alternator. Does this look right to you?
This is temporary to see if this is correct and if it works.
Old Nov 30, 2024 | 07:08 PM
thomas68's Avatar
thomas68
68's have an alternator. They had an external voltage regulator mounted on the fender well area. Not sure about the bypass you have going on.
Old Nov 30, 2024 | 08:35 PM
Jd21476's Avatar
Jd21476
Oh ok, so I bypassed the voltage regulator but Im not sure that I did it properly
Old Dec 1, 2024 | 01:23 AM
carriljc's Avatar
carriljc
Jd21476
The 68 had externally regulated Alternator (AC Generator).
Check out the link below:
The color of the leads may not be exact but you can follow them back per the attached diagram.
It is for converting to a 12SI and I do NOT recognize that oddball Alternator you have going there?
I converted mine ages ago but I soldered the leads together and eliminated the whole voltage regulator connections.
If I remember I'll look tomorrow to see what leads I joined together.
What is that weird alternator you have there?
http://wallaceracing.com/alt-conversion.html
Old Dec 1, 2024 | 01:36 AM
Jd21476's Avatar
Jd21476
The car is an LS swap so that is an alternator for my LS6 that is now in the car.
Old Dec 1, 2024 | 02:06 AM
carriljc's Avatar
carriljc
Jd21476
Could you tell me the alternator model/part number.
It may be a Pulse Width Modulated (PWM) controlled alternator. I was researching one of those (in fact I have one to install to replace my CS-144) and if you have the appropriate LS ECM and harness then the old external regulator wiring will be pretty much unnecessary...... your ECM will control it.
OR, you can use external controls for PWM
Old Dec 1, 2024 | 11:25 AM
SteveG75's Avatar
SteveG75
Here is what I found at chevelles.com:
https://www.chevelles.com/threads/pl...ulator.515770/
At the external regulator;
The blue wire is jumpered to the brown wire. The white wire and the orange wire are capped off so that they will not short out to anything.
So, remove that middle jumper wire and just jump the brown to the blue.
Old Dec 1, 2024 | 09:36 PM
carriljc's Avatar
carriljc
Jd21476
Did you end up getting the alternator you mention in the post below? The PowerMaster 584061?
https://www.corvetteforum.com/forums...post1608045048
If so, then per summit racing equipment website that is a GM CS130D/AD Alternator.....
https://www.summitracing.com/parts/p...EWnBcsiaDwMMIm
and within that website it tells you what alternator it is....GM CS130D/AD Alternator.... and sends you to this page: https://static.summitracing.com/glob..._cs130d_ad.pdf
SO - is that 2 pin or a 4 pin connector on your alternator?
To Bypassing generator for alternator
