Intake Manifold Bolt Washer Thickness
Old Dec 2, 2024 | 05:21 PM
C3 73's Avatar
C3 73
Default Intake Manifold Bolt Washer Thickness
I'm getting ready to re-install my intake manifold after cleaning it up and needing to install new gaskets.
I bought a set of ARP SS bolts and four of the eight come with washers that are slightly thinner.
Where on the manifold should these be placed?
Thanks!
Old Dec 2, 2024 | 06:59 PM
Piersonpie's Avatar
Piersonpie
I just bought the same ones, 434-2101 correct?
I believe they go on the front four holes, to gain more access around the coolant crossover.
Old Dec 2, 2024 | 09:57 PM
C3 73's Avatar
C3 73
Yep, that's the one! Hopefully someone else can verify your hunch. Thanks
Old Dec 3, 2024 | 11:13 AM
C3 73's Avatar
C3 73
I had a second thought could the thinner washers be used at both the forward and rear (I'd say aft, but that might seem too nautical) most mounting points because those are blind threads? All the other mounting points open to the oil galley below.
Old Dec 3, 2024 | 03:02 PM
OMF's Avatar
OMF
Those 4 thinner washers go in the two hole on either side of the carb base, where space is limited.
Old Dec 3, 2024 | 03:26 PM
HeadsU.P.'s Avatar
HeadsU.P.
The four outside corner holes are blind holes.
You do not want a bolt to bottom out there.
So use the thicker washer.
Smaller diameter washers?
Any place interference from the casting is present.
Don't forget thread sealant.
Old Dec 3, 2024 | 03:51 PM
C3 73's Avatar
C3 73
That was my other thought, just wasn't as sure.
Old Dec 3, 2024 | 03:59 PM
C3 73's Avatar
C3 73
Good point. I was thinking more that you'd more threads, but that makes better sense.
Thread sealant? DEFINITELY!! That"s the main reason I started this. Five of the eight bolts would ooze oil until the engine warmed up.
To Intake Manifold Bolt Washer Thickness
