"New"bad front caliper
Old Feb 8, 2003 | 05:37 PM
J75's Avatar
J75
Default "New"bad front caliper
Ordered a set of the new sleeved front calipers from Mad,$129 a piece.While bleeding the LF I noticed a nice fluid leak.Checked all the fittings and all was fine.Removed the caliper to check and one piston and seal hit the ground. :mad Seems the sleeve is not pressed flush in the bore so the outer seal can not be pressed fully in.Sure Mad will replace it at no charge but that does not account for the poor quality control and my time.If I preformed my job to those standards I would be gone.Just wanted to pass on the info,be sure and check these close if you buy them.Other wise they look great but that don`t stop the car.
[Modified by J75, 10:38 PM 2/8/2003]
Old Feb 8, 2003 | 09:11 PM
Stoge's Avatar
Stoge
Default Re: "New"bad front caliper (J75)
Irritating...
Old Feb 9, 2003 | 01:45 AM
java0881's Avatar
java0881
had the same thing happen when i ordered a set from chicago corvette.
1 was leaking from the piston,anotherone was chipped off right by the bleeder.of course the replaced it ,but i still paid the shipping and had to wait longer.
best bet is to pick it up local so you can inspect what you buy and no shipping charges either
Old Feb 9, 2003 | 06:02 AM
WESCH's Avatar
WESCH
Hi
I understand the problem with the outer seal ( dustseal ) not staying tight in the caliper, but this seal is not the cause of the leak.
The inner lip seal should still work, even with the sleeve not 100 % fluch on the outside.
Get an other caliper, this one is not OK for a Vette.
Good luck Gunther
To "New"bad front caliper
