1969 427/435 Spark Plug Cabling Question | Crossfire
Old Jan 2, 2025 | 09:32 AM
Scott Hill's Avatar
Scott Hill
Default 1969 427/435 Spark Plug Cabling Question | Crossfire
Good morning all!
A little confusion about the wiring order for the grommet pass through on both the passenger and driver side. I have the driver side identified as 7-3-5-1 starting from the top left going clockwise. I can't find anything that shows the passenger side, other than what zip-corvette shows on their site as 4-2-8-6 starting top left and going clockwise, or on this forum someone posted the NCRS manual shows the passenger side as being 8-4-2-6. I can't find the NCRS manual that shows this information.
Could anyone provide clarification? Worried about crossfire.
Cheers!
Scott
Old Jan 2, 2025 | 10:04 AM
robertea's Avatar
robertea
This is from the 1969 AIM.
Old Jan 2, 2025 | 01:24 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I never knew they had a diagram. I just put them where they wanted to go and fit the best. It doesnt matter if you have good wires. I use 8mm with an MSD and dont have any wire to wire issues
Old Jan 2, 2025 | 03:16 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
(The AIM wiring is under the radio option detail pages.)
The issue that GM was addressing is that #5 and #7 are right next to each other in the firing order and any spark jumping between them is no good, so are routed with as much separation as possible. The passenger side doesn't have this issue so the order is just a CCW 2,4,6,8.
The '72 AIM is even more specific showing that the #5 & 7 should be at opposite ends of the wire holder on the valve cover.
Old Jan 2, 2025 | 06:55 PM
HeadsU.P.'s Avatar
HeadsU.P.
Known as the dreaded: Inductive Crossfire
Old Jan 3, 2025 | 05:28 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Thanks for that Richard mine were wrapped around each other . Not now though
they even fit in there better. Never knew that illustration existed.
To 1969 427/435 Spark Plug Cabling Question | Crossfire
