427 ZL-1 Dyno Test
https://www.hotrod.com/how-to/nos-42...and-dyno-test/
555HP at 6300 rpm.
Mostly NOS parts...but...
they tamed the cam down 14 degrees.
The cam they used is 6 & 12 degrees larger (@ .050") than the L72 /LS6 cam.
Comp Cams (PN 11-773-8). With duration of 248/254 and lift of 0.653- and 0.660-inches of lift, with 110 LSA
vs 262/273 for a real ZL-1 cam.
The sound of that ZL1 engine was just awesome, it was "music" to my ears. That Gulf Oil Racing Corvette sure was a "hit" with the crowds whenever he would start the engine up. It sounded ferocious just idling there and when he would "blip" the throttle you could "Feel" the engine's power.
Unfortunately there were not enough of the ZL1's made and people have been trying to "copy" one ever since. I have heard so many stories about how their Dad bought them a real ZL1 while they were in high school....
Thank you for taking the time to share this with us! I really appreciate it!
Best regards,
Chris
So the question is would a 14 degree larger cam actually be any stronger?
Normally yes - maybe 30-50HP worth. And at say 700-1000 rpm more.
But doesn't going from an old school solid cam to a mechanical roller also make up a similar increase?
So would going backwards to a solid flat lobe profile, even with more duration, actually make any more power? Maybe some? Maybe none?
For sure it would rpm better.
With the old cam, I would guess 560-580 HP at closer to 7000 rpm.
But maybe not.
Any other opinions? Or L88 Experience?
One thing is for sure, it is lighter than an all iron small block. And a powerhouse. 56 years ago!
Complete engine weights: (dry, flywheel/WP/oil pan/dist)
(based on the sum of component parts)
All iron BBC: 646#
BB AL heads, intake, wp: 554#
All iron SBC: 516#
SB AL heads, intake, wp: 450#
ZL1 AL heads, block, intake, wp: 474#
The car ran 10.70 at 127 in good air. I guess car weight was around 3,400 (all steel) plus 200 for me equals 3,600. Plugging that weight and MPH in Wallace calculator yields 568 hp. Similar to your thinking.
Best regards,
Chris
If I recall correctly there were two tests in the late 1980s or early 1990s… One was a ZL-1, the other was a second design L-88 (which was basically the same engine without the aluminum block). Those engines were both relatively stock and; output was something in the range of 525hp - 535hp which is pretty darn good. Some cylinder head work would add a bit more to those numbers. I’m putting together a second design L-88 that will be completely stock. I’ve been toying with the idea of having it dynoed just to know what I’m working with. If I do, I’ll post the results (I’m probably a year out).
Based on what I have seen, my opinion is that there is no direct proof that ties that car (#10209) to being a ZL-1. There IS direct proof that shows it as the third L-88/M-40 built. The games played with the dealer invoice(S), the tank sticker(S), and the attempt to verify the tank sticker through NCRS are well documented on this forum.
Regards,
Stan Falenski
Regards,
Stan Falenski
Not really aware of all that. I always thought of the car as an L88 or clone of either until the magazine article that came out about the car. It stated that GULF oil had written a letter asking GM for the ZL1 TH400 combo and that is how it was delivered. I know of no details on it other than seeing the car for years in Carlisle. I do know car number 1 though as it came through VA and was restored by Wayne Walker.
Justin
Justin
Thanks for your response and my apology if my initial answer was a bit terse.
I’ve known about the orange car (#10209) since the early 1980s and I’ve been involved with it (off and on) since that time. I’ve heard all the stories and seen the various versions of paperwork associated with it… After a while, it gets old trying to keep the story straight. In any case, the car is a real L-88/M-40 car; I’m not willing to go any farther than that.
As you mentioned, the yellow car (#29219) is well documented and is the only 1969 ZL-1 Corvette that I am aware of that is, without question, real.
Regards,
Stan Falenski
After putting the L88 Hood on my 1968 C3 convertible, the paint was done to match the rest of the Corvette. At this point I made sure that everyone who saw it, knew it is a CLONE and not a real L88. The only time I was not near hovering near the C3 was when the SpeedVision people saw it and were filming a short segment on my Corvette. I stepped in and made sure that it was noted that this was a "Clone" and NOT an original. The speaker was asking the viewers why a Virginia resident would drive it up to PA? It was obvious that it was not trailer-ed as it was still dirty from the ride up. I saw the segment on SpeedVision and they did not mention that it was a clone.
If you ever watch a speed vision show about Corvettes@Carlisle and they have a segment with a bright, Daytona Yellow, 1968 C3 wearing a L88 hood from Virginia, you will have seen my C3. I have a radio and a heater which should be dead give-a-ways for anybody who knows Corvettes.
Honor the originals, but drive the clones like you stole them! The L88 power is intoxicating and very addictive to boot. I keep the tail lights clean for the followers to appreciate them..... Thank you Zora!!!
I had to compare the power curves!
LT-1 vs ZL-1
(Since I now had dyno tests on both engines)
What struck me the most was the very similar RPMs at which the peak HP and peak TQ are made.
The cams are pretty similar, and of course they both rev like crazy!
That BB revs like a rev-happy small block.
(Of course a real ZL-1 had a little bigger cam, but so did the DZ 302. Kind of similar cams, again.)
Engine: 1970 LT-1 vs ZL-1 (Hot Rod Version)
Block: SBC vs BBC
Cu In: 350 vs 427
Block: Iron vs Aluminum
Block Weight: 165# vs 120#
Engine Weight: 502# vs 554#
HP Peak RPM: 6100 vs 6200
TQ Peak RPM: 4700 vs 4200
In Cam dur @ .050": 242* vs 248*
HP/Cu In: 1.05 vs 1.23
TQ: 372 vs 526
HP: 367 vs 555
But the extra 154 TQ and 188 HP is just irresistible!
From only 77 extra cubes.
LT-1 Dyno Test
My cousin is Jerry Hanson he at one time owned and raced the old Owens corning vette, that was a very cool car.
That glorious noise!
It ruined me for life!
