Ring & Pinion setup Help Please
Old Jan 7, 2025 | 02:53 AM
Got2Many's Avatar
Got2Many
Default Ring & Pinion setup Help Please
I just got a 1969 L71 car. It has 3.08:1 rear-end gears. I am going to change to 3.70:1 (with rebuild on the rest). I am looking for a SETUP BEARING (so that I can avoid pressing an actual bearing on and off). I've call a few places, but no one thus far has been able to help me.
Do any of you know is the C2/C3 (all but the last few years) shares a pinion bearing with? And where I might be able to acquire one?
Thanks in advance, Mac
Old Jan 7, 2025 | 04:08 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
C2- C3 though the 79 model year is a Corvette specific diff. I really don't believe there is a lazy way, or cheaters way around this.
Old Jan 7, 2025 | 07:25 AM
69L88's Avatar
69L88
Simple enough to make your own. Take a new bearing and a rotary sanding drum and carefully remove material to allow for a slip fit.
Old Jan 7, 2025 | 02:42 PM
Got2Many's Avatar
Got2Many
Thank you both!
I thought may it might share pinion bearings with one of the more common 10 bolts. I have the fancy tool to pull the bearings. I always start with 2 fresh Timkens as close as I can get them to each other. Then once the 1st is shimed, install the fresh one and check. The cheater bearing is marginally helpful.
It looks like it shares pinion bearings with a garden variety 8.5in 10 bolt??
To Ring & Pinion setup Help Please
