LED Replacement Question
Old Jan 23, 2025 | 09:55 PM
oilngas's Avatar
oilngas
Default LED Replacement Question
When switching to LEDs why is it suggested to replace clear bulbs with red when the lens are already red?
Bulbs have always been clear with colored lens. Accept natural amber bulbs that were used with clear lens.
Old Jan 23, 2025 | 10:42 PM
BLUE1972's Avatar
BLUE1972
supposedly the red shows brighter, as it's not filtered as much as a clear bulb by the lens to get the red view.
Old Jan 24, 2025 | 01:04 AM
ZIOGEO's Avatar
ZIOGEO
I used clear on my 73 vette and they work fine. I used red replacement LED's on my daily driver VW and I cant tell the difference.
Old Jan 24, 2025 | 05:18 AM
oilngas's Avatar
oilngas
You can't tell the difference in white and red LEDs? Or you can't tell the difference in red LEDs and the incadesent {sic}
Old Jan 24, 2025 | 07:08 AM
VetteLooking's Avatar
VetteLooking
LEDs are brighter and generally have a cooler light color temperature compared to incandescent. They also generally have a more directional light. Putting a clear LED behind a red lens has the possibility of making it look washed out and more pink than red.
There are many factors involved and you might be fine with the look of a clear LED. I personally would use red if you can get it.
Old Jan 24, 2025 | 07:20 AM
Eliredandblack's Avatar
Eliredandblack
Really, the most important factor is making sure the LEDs are not Polarity Sensitive! Superbright LEDs are vey high quality, you cant go wrong.
Old Jan 24, 2025 | 10:52 AM
ZIOGEO's Avatar
ZIOGEO
Meaning regardless if the LED color is red or white, if its in a red tail light housing it looks the same (to me). I was primarily motivated to change the tail lights and the front directional to LED because they are brighter and easier for other drivers to see. I will note on my 73 I did use the amber LED's in the front because the lens is clear so a white LED will obviously not work. But with a red tail light lens I could not tell the difference in a red or white LED. I also agree with Eliredandblack, Superbright LED's are a decent product. Just note, if you change to LED's for ANY of the directional bulbs, you will need to use an electronic flasher.
Old Jan 24, 2025 | 11:51 AM
conrailbob's Avatar
conrailbob
question....is an "electronic flasher" an aftermarket electronic part and where might it go?
Old Jan 24, 2025 | 12:00 PM
Bikespace's Avatar
Bikespace
A red LED emits photons in the red wavelength range. A "white" LED is actually a blue LED with a yellow phosphor.
If you want to emit red photons, and shine them through a red lens (which will absorb non-red photons), a red LED is more efficient. Either will work, but a red LED will likely be brighter to the eye.
https://www.corvetteforum.com/forums...s-learned.html
Old Jan 24, 2025 | 12:20 PM
ZIOGEO's Avatar
ZIOGEO
It would replace the flasher located on the passenger side above the kick panel. My 73 still had the OE flasher, a little blue can with two spade lugs. The electronic flasher I used is an adjustable (meaning the rate at which the directional lamps blink on/off is variable). I think I bought it from Superbright but you can prob get them from almost anywhere.
Old Jan 24, 2025 | 01:27 PM
oilngas's Avatar
oilngas
I would assume you actually need two flasher. Thank you for the explanation. I think I will go with amber and red bulbs,
To LED Replacement Question
