71 454 puking coolant
If you look on the side of the tank you'll see it indicates it should only be half full when cold.
This allows for fluid expansion when the coolant is hot.
Try reducing the level and see if that corrects your issue.
If not it could be that your pressure cap is weak and needs replacing.
I have an early 1968 C3 with a BB and my car did not come with the aluminum surge tank in it. My car started life at the factory with it's BB but they never drilled the holes to mount the bracket that supports the weight of the surge tank. On my 427 I had to use a standard overflow tank connected to the radiator below the radiator cap. This allows my coolant to expand and go to the overflow container and as it cools it draws the coolant back into the radiator.
Without the overflow tank my engine would spit out coolant as it heated up. When the engine was cooled back down again I could open the radiator and see that the coolant was a couple quarts low inside the radiator. Without the expansion tank allowing for the extra coolant I would risk running my engine hotter. With a radiator full of coolant it makes an amazing difference in it's ability to cool down quickly.
No matter if you have a surge tank or not I would verify that your cooling system has a path to overflow excess coolant into a sealed container. The tube connected to the radiator just below the radiator cap needs to be good enough to hold vacuum allowing the radiator to draw in coolant as it is cooling down. If the radiator cap is old and no longer working then your overflow system will not work. If you have a leaky hose on the expansion tank then it will not draw coolant back into the cooling system.
If my 427 started "puking coolant" I would probably start by looking at the ignition timing of the engine. The BB engines seem to be very sensitive to having the ignition timing being retarded. On my engine I have the mechanical advance (centrifugal) in my distributor as well as a Vacuum advance. One day my engine was running hotter than normal so I checked the vacuum hose going to the distributor and I found it had a hole leaking the vacuum and not advancing the timing to the full 36-38* of timing I generally run. This happens often in our world and the hoses need to be checked regularly to prevent issues from happening. Without the extra advancing from the vacuum advance my engine was not running at its best.
Aluminum Radiators, Modified Thermostats, higher flow water pumps and many other parts are available to "enhance cooling". I am a big believer of the Redline Water Wetter as it helps the engine get rid of the heat a bit better. It is a "surfactant" and will help prevent the layer of tiny bubbles that form on the inside of your cooling system on the metal surfaces. These little bubbles actually "slow" the heat transfer between the coolant and the metal inside your engine. The Water Wetter does work but will not deliver a 25* reduction in coolant temperature, there are many variables like how much coolant your engine holds. My 427 hold about 22 quarts of coolant and I only run 30% anti-freeze with 70% Reverse Osmosis water. Too much anti-freeze and the cooling ability will be reduced, too much water and your freeze protection is weakened. Since I live in an area where we spend more time "cooling" than "heating" so I don't need -40* protection. I saw a Asian Car that somebody had 100% anti-freeze in the cooling system and they wondered why the car was overheating.
I hope this gives you an idea of where to start looking for the "cause" of your engine puking coolant. I personally am using a coolant that is completely water-less and uses zero pressure inside the system. This coolant is supposed to eliminate Hot spots inside the engine and thus virtually eliminating detonation from occurring. The only negative is that this stuff is close to $100 a gallon and I use over 5-1/2 gallons of this material in my cooling system.
Now, I'd like to know, while I hate to remove the original "Harrison" surge tank, if the late 74-77 overflow tank will fit these? I'd like to get rid of that and run a conventional overflow tank with a radiator cap. Radiator is a Aluminum "Be cool" unit. It does have provision for a cap.
It would seem that using a expansion tank in the lines going to the heater core would make the overflow system useless. On my 427 I run just an overflow system and I don't have the big Aluminum Expansion (surge) tank.
The Overflow System used on the C4 Corvettes might be something you could re-engineer to fit in your engine compartment. The most important part is to have a working radiator cap with the provisions for a tube to take the excess to the reservoir. The tank has one line that comes from the overflow below the radiator cap that takes the coolant to the Overflow container. The overflow container should have a lid on it and are usually clear so you can see the fluid inside the overflow tank. The tank is vented at the tank level. When the coolant gets hot it will expand and move into the overflow tank. If the Overflow systems vacuum tube is good, it should pull the fluid back into the radiator as the system cools down and shrinks. If the overflow vacuum tube is too soft, it can close off preventing the fluid from returning to the radiator by collapsing under the vacuum. I use heavy vacuum hose or even fuel injection hose to connect the overflow system. I also replace my radiator caps on a schedule to prevent cooling issues.
My understanding is, since the highest point of radiator is lower than engine, they put this "tank" somewhere higher to bleed the air out of system. otherwise I don't see any other point to put a pressurized tank there. I can easily vacuum fill the system like many newer cars. will look into C4 stuff.
Have you found your pressure tester?
Actually... not really. 30 minutes later it lost 1 PSI. now sitting at 14 PSI.
