water temperature sending unit
Old Feb 15, 2025 | 07:33 AM
Shoshinru's Avatar
Shoshinru
Default water temperature sending unit
I own a 74 coupe, 350 L48 with 4 speed. We just swapped out the old 350 for a Summit 350/290hp engine but we are having issues locating a water temperature sending unit that will work with the original gauge. The original sending unit was 1/2" pipe thread, the new block is 3/8". I have yet to find a compatible sensor..Ideas? Thanks
Old Feb 15, 2025 | 08:21 AM
ctmccloskey's Avatar
ctmccloskey
I used a thermostat housing that had the 1/2" hole already in it. Here is the type of part I used initially and it worked great. This one is on the JEGS website.
https://www.jegs.com/i/Dorman-Produc...-2009/10002/-1
Is this what you are looking for by any chance? It would allow you to use the sensor that came with your Corvette.
Old Feb 15, 2025 | 09:22 AM
HeadsU.P.'s Avatar
HeadsU.P.
I was lucky and caught that size difference in the cyl head BEFORE I put the heads on.
Not so lucky for you, however.
I did not want to give up my tried & true GM sensor. Nor buy an aftermarket unit and calibrate, and hope it is accurate.
So, a local machine shop drilled & tapped the head for $30. Perfect!
Is that an option for you?
Old Feb 15, 2025 | 05:40 PM
Shoshinru's Avatar
Shoshinru
Yes, thanks for the solution!!
Old Feb 15, 2025 | 05:43 PM
Shoshinru's Avatar
Shoshinru
No, the engine is installed now. I'll use the thermostat housing. Thanks for your reply
To water temperature sending unit
