Tach Problem
Old Feb 15, 2025 | 05:57 PM
Archangel67's Avatar
Archangel67
Default Tach Problem
Hello all,
I have a 1978 Corvette with the original (but recently rebuilt) 350 ci, L82 engine. It's been running nicely. I cold started the engine today and as it was warming up at high idle I tapped the throttle to bring the rpm down and the tach buried itself off scale at 7000 rpm. The engine remained at high idle so I shut it down. When I turned on the ignition switch the tach needle resets to around 6500 rpm and then after start, it buries itself again at 7000 rpm. The engine runs just fine. Is the tach board fried? Any other ideas?
Thanks,
Tom
Old Feb 16, 2025 | 12:40 AM
ZIOGEO's Avatar
ZIOGEO
Yup. Most likely tach board.
This explains it
https://www.corvettemagazine.com/197...ometer-repair/
Old Feb 16, 2025 | 12:59 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
My money is on the tach board. Good news is, I replaced mine late 90's early 2,000's. And it's been better than new ever since.
Old Feb 16, 2025 | 08:05 AM
MBjeep's Avatar
MBjeep
Can a bad board also cause tach to run high? Mine at idle shows 1100ish but the engine is lower at about 650.
To my ear it sounds about 600 and I checked rpm with 2 different external tachs attached to tach pigtail on dizzy and they both show 650.
Old Feb 16, 2025 | 12:21 PM
Archangel67
Thanks, everyone. If the tach board is, in fact, the culprit, will the needle reset to zero once I apply power to it or do I have to somehow reset it manually?
To Tach Problem
