Trailing Arm Tools in Australia
Old Feb 17, 2025 | 07:17 AM
DaveC82's Avatar
DaveC82
6th Gear
Default Trailing Arm Tools in Australia
Hi Australians,
I'm going to rebuild my trailing arms shortly, and before I went and bought the right tools I thought I'd see if anyone had them locally and would loan them out (for a postage + fee + slab). If not, I'll buy them and will reply to this post offering mine to loan out in Aus in about 2 months time as otherwise they'll be sitting on a shelf and achieving poor asset utilisation.
I'm after the obvious tools specifically:
1) Spindle Removal Tool
2) Outer bearing removal tool
3) Spindle Mock up tool
4) Trailing Arm Bushing Install Tool
Cheers
DC
Old Feb 17, 2025 | 08:34 AM
GTR1999's Avatar
GTR1999
The tools you need to remove the axle are the knocker tool about $20 and 4 or 5 lb hammer.
To set up the bearings you need to decide how you want to do it, common like most, then you need the shim kit which won't have shims close in size. To dial them in for -0- lateral play you need to know how to do it and have a surface grinder.
An old axle will work if you polish it undersize and make a handle, a setup tool with a knurled handle works better. To install the axle on the bearings a common hydraulic press with tubes the diameter of the inner cone race.
For a set of bushings, you can make a tool using the end of a pneumatic tool shank, two steel plates and some bolts.
Those axle press tools sold will bend the caliper bracket. Using a press to remove the axle can bend the arm.
Old Feb 17, 2025 | 08:43 AM
interpon's Avatar
interpon
If you mail these tools, really wrap them good..
i lost a set of blocks and trailing arm tools (free loaner program LOL) to the post office.. arrived empty..like a machine tore it up.
Old Feb 17, 2025 | 09:40 PM
GTR1999's Avatar
GTR1999
There was a time I loaned out my tools, no more. Shipping is just one reason.
Old Feb 18, 2025 | 03:32 PM
bazza77's Avatar
bazza77
Originally Posted by DaveC82
Hi Australians,
Cheers
DC
where are you in Australia ?
Old Feb 18, 2025 | 09:35 PM
DaveC82's Avatar
DaveC82
6th Gear
@bazza77 The wrong side it would appear - Melbourne
Old Feb 19, 2025 | 02:31 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm Sunshine Coast. I have everything, but not keen to lend out tool to pull outer bearing. PM me.
Old Feb 19, 2025 | 04:37 PM
jthornton's Avatar
jthornton
A quick google search found a drawing for the bearing setting tool so if you have a mate with a lathe you could make one.
JT
To Trailing Arm Tools in Australia
