Hi everyone, it's been a while since I last wrote, and I hope you're all doing well!
I'm reaching out regarding my 1974 C3. The car was sitting idle for about three months due to the registration process in Italy (which was successfully completed). Yesterday, I took it out for a drive after a long time (although I had started it a few times and let it run while stationary in the garage), and it didn't feel great.
The engine doesn’t seem to be running smoothly, especially at low RPMs (up to 2000 RPM). Additionally, at one point, it felt like the power delivery cut out for a fraction of a second.
On top of that, I heard a few backfires (which improved after running for a few minutes).
What could be the issue? A friend suggested it might be the distributor, the ignition coil, or possibly a dirty carburetor.
Thanks in advance for your opinions!
P.S. The car will be at a mechanic’s in the next few days for a full service.
Gummed up carburetor certainly fits all your symptoms. Obviously your mechanic will check all the basics as well. But a good cleaning of the carburetor is likely the solution to your issue.
First thing to check is that all plug wires are securely seated at both ends.
Do you still have the points distributor?
Still have the stock QJet carb?
How fresh is the gas?
yes, car is 100% original
regarding fuel freshness: i left one liter, maybe two, during winter break. Then yesterday I did 10 liters. Is it wrong? Do you usually remove all the fuel for winter break? thanks for your support!
I really doubt Seafoam is available in Italy. Unless Italy has its own source of Amazon, perhaps.
You may have your own version of Seafoam in Europe.
Basically, it's just a fuel tank, lines, and carb cleanser. You pour some in the tank and some down the carb at a fast idle.
For what it's worth, my first run down the road in the spring is on 6 cylinders. Then 7. Then 8.
Clears up after a couple miles. Then I fill with fresh gas.
I wouldn't be too concerned with your misfire issue at first. Condensation under the distributor cap.
Rusty plugs, carb full of moisture, sticky valves, lifters not pumping up, etc.
After several miles and the issue continues, then you have a problem.
Whenever I put my cars away for winter, I make sure the tank is full of fresh gas. Eliminating as much air in the tank as possible helps keep condensation to a minimum and I think helps slow the aging of the gas. Around here I fill with non-ethanol premium so have longer storage life to it anyway. (I often use ethanol premium during the summer because I'm not looking for long-term storage from it.)
I'd do as HeadsU.P. said and run new gas through it for a bit. Take it up to 4000 a few times and see how it behaves after a few heat cycles.
I have just found it!
so, if i understood correctly, some in the tank with low gas, plus some in the carb with fast idle (i assume i have to remove the air filter to do it, right?)
then I run the vehicle for a while and then more gas in the tank, correct?
Unlikely if you’re not pouring too much in at one time, but if you do manage to flood it I would just wait a bit or restart it with your foot to the floor on the gas pedal.
What you described is how my car ran when I accidentally put the vac advance on the wrong port. On ported vacuum, it ran like crap, but was "original". With manifold vacuum, the extra 10-12 degrees of advance made all the difference for a smooth idle.
I would find a bottle of BG 44K and put in the gasoline and just "drive it" clean. Nothing works like BG 44K does, hundreds of new car and used car dealers use it every day for cars under warranty that need to run better or idle smoother. It is available on Amazon and in other parts of the world. BG 44K makes my cars all idle as smooth as glass, this stuff is amazing
They make kits for serious cleaning of the intake parts that use a couple different bottles of liquid. One goes in the fuel tank and the other is drawn into the injection system through a vacuum line. One of my neighbors used Seafoam and another neighbor called the fire department not knowing that all that smoke is "normal". That smoke was nasty and thick.
been using ethanol for 35 yrs nothing wrong with it as long as you drive it and don’t let it sit for long periods .
