Low Profile Intake C3 swap
Old Mar 10, 2025 | 04:10 PM
mikejana's Avatar
mikejana
Veteran: Marine Corps
Default Low Profile Intake C3 swap
I've got all of the parts together for a Blueprint engine/200r4 swap into my 77 corvette, except for an intake.
I'll be running mid year OEM valve covers with the corvette script; These vale covers do not have oil access.
Need advice on a low profile intake manifold to fit under the stock standard hood.
I like the Weiand 8120 & 8125, but it does not give me access to add oil.
Suggestions are appreciated.
Old Mar 10, 2025 | 04:46 PM
Bikespace's Avatar
Bikespace
When you drill a hole for the PCV and breather vent, you can add oil to either of those holes.
Old Mar 10, 2025 | 06:17 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Here is a list of what fits height wise. With stock low profile air cleaners.
The LT-1 is a bit too tight on a 72 stock hood. But a 77 does have a little more room.
I can not help you with the oil fill though.
Maybe the old C2 L76 intake?
IIR does it have an oil fill tube?
Old Mar 10, 2025 | 06:34 PM
HeadsU.P.'s Avatar
HeadsU.P.
Mike,
Here is an Intake from Edelbrock that not only has the hole for an oil fill but comes with the chrome tube and cap also.
Eddy 2703 around $325
However, you will have to go to Eddy web site and check the carb pad height on that model.
I will warn you that about every SBC Intake they sell has a asterisk*
*Will Not Fit Under Corvette Hood. This is a liability thing so as not to get Intakes returned for a refund.
There should be another asterisk* that says, yes it will if you know how to do it.
Old Mar 10, 2025 | 07:57 PM
litevette's Avatar
litevette
Great chart! Thanks for sharing. Saving that one in my “‘Vette stuff” files!!!
Old Mar 10, 2025 | 09:12 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Originally Posted by HeadsU.P.
Mike,
Great find!
It's another version of the EPS with an oil fill tube.
And it has a 4.2" pad height, so it is in the will fit range.
Old Mar 11, 2025 | 10:38 AM
mikejana's Avatar
mikejana
I culled this from the forum a while ago
File Type: docx
Old Mar 11, 2025 | 09:55 PM
509 rat's Avatar
509 rat
Default engine
What motor and the weiand team g is very good and should clear .
Old Mar 12, 2025 | 09:23 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
A 100% stock intake & air cleaner setup on a 72 gives you 3/4-1.0" of hood clearance.
With a 3.5" intake. A 4.2" does fit but starts to get tight.
Stock style drop air cleaners must be used.
A 4.5" does not fit.
But on 73-78 has a little more hood room due to the scoop.
No one has been able to say exactly how much.
Old Mar 12, 2025 | 10:20 PM
mikejana's Avatar
mikejana
Rat 509-
I ordered the Blueprint 350 ci 390 hp long block.
Have a set of SS side pipes from High Flo and we have a set of original GM aluminum side pipe covers.
Old Mar 13, 2025 | 11:45 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I just did a clay check on a stone stock 74 with the stock domed hood, air cleaner, etc. including .25" thick carb gasket.
It had 1-5/8" air cleaner to hood clearance as stock.
They have 1-1/8" more hood clearance than a 72 std hood does.
So even a 4.75" pad ht RPM air gap could be made to fit.
Old Mar 13, 2025 | 12:34 PM
mikejana's Avatar
mikejana
Thanks Leigh, great information!
Old Apr 30, 2025 | 03:05 PM
mikejana's Avatar
mikejana
All this reseach I went with the Blueprint low profile. They claimed it to be a clone of the zz4. It's not going to work for oil service, there is no safe way to cut a hole without hitting a water passage.
It looks like the 3 Edelbrock performers (2101,2104 or EPS) or an LT-1 will fit the bill for adding oil, do any of these fit a Quadrajet?
thanksagain
Old Apr 30, 2025 | 03:39 PM
Newbomb2469's Avatar
Newbomb2469
Square bore on the left, spread bore on the right
Another spread bore intake manifold
Old May 1, 2025 | 08:58 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
As in the pics above, some fit SQ only, some fit spread only, some fit both.
Old May 2, 2025 | 08:50 AM
theandies's Avatar
theandies
Can't help you with your oil situation but I just installed a Weiand 7530WND single plane Team-G intake on my ZZ4 and it fits under my 1971 base model stock hood. And no, I don't feel any loss of low end torque from my butt dyno going from a dual plane to single plane.
Hood clearance check. Have plenty of room except for the passenger side which is close at 1/4" or so:
Old May 2, 2025 | 09:07 PM
509 rat's Avatar
509 rat
Team g all the way I have that intake on a 434 makes over 650 and 327 that's pretty much stock and worked great.
Old May 3, 2025 | 12:55 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
As well you shouldn't with EFI. Keep it real, dual planes are for carburetors.
To Low Profile Intake C3 swap
