Rear end ratio
Old May 1, 2025 | 05:49 PM
Dreamcar79's Avatar
Dreamcar79
8th Gear
Default Rear end ratio
My 79 vette has a rearend stamp of AW A 06 0 E 1
Can someone tell me for sure is that a 3:08 Ratio and what it all means I looked some up and in my 79 it maybe isn't the original rearend ????
Old May 1, 2025 | 06:03 PM
USMC6113's Avatar
USMC6113
The only sure way to know the ratio is to mark the tire and driveshaft. Rotate the tire 1 revolution and count how many times the driveshaft turns. I have no knowledge of the originality part.
Old May 1, 2025 | 10:39 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
The last AW code was used in 1975 for the 3.08 gearing, as a matter of fact, all uses of AW were for 3.08.
I am having a tough time finding my date code translation guide, but I think it's January 6th, 1970, Eaton, shift 1. But that is kinda troublesome because 1970 Corvettes used CAW while '69 and '71 used just AW. That's also complicated by the extended 1969 model year into December of '70...
Old May 2, 2025 | 04:37 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Just because the case is stamped with a factory stamp from 50 years ago, and then not even in the original car,
Well, basically means nothing.
Could be anything in that case now. Mark the drive shaft and count.
Who would put in a 3:08 on purpose?
Old May 2, 2025 | 05:19 PM
USMC6113's Avatar
USMC6113
Bubba
Old May 2, 2025 | 07:37 PM
socal_tom's Avatar
socal_tom
My 70 has 3.08 and I am going to switch to 3.73
Old May 3, 2025 | 12:37 AM
Way's Avatar
Way
True,
I removed my 3:08 to make room for a 3:73
Old May 3, 2025 | 08:00 AM
pltmgr's Avatar
pltmgr
If you don't want to jack up the car and count revolutions I believe here are formulas on line that can determine the rear diff ratio based on tire size, vehicle speed, and RPM.
Old May 3, 2025 | 09:49 AM
GTR1999's Avatar
GTR1999
Very good explanation. A lot of 79's had 355's.
Now, if it is a 1975 diff and original, just bolted into the car, there are some issues within it that should be checked. Maybe they were already addressed, maybe not. If the diff is not leaking, whining, or has excessive axle endplay I would drive the car. If it has any or all of those, I would consider checking it more closely and that means removal.
There is casting date on the lower left side, look to see what it is. Chances are it is not the original diff. That doesn't mean it is bad, I use a lot of 72-79 housing for foundations to build much stronger diff's from.
To Rear end ratio
